12 days since Maxdsl regrade now problems
amjrobson
My DSL line was maxed 12 days ago for the first 10 days it was great syncing between 2900 and 3200 with no interleaving with a DS SNR of 6. Then on Sunday evening the line lost sync and just wouldnt connect. I powered the router off over night and tried it again in the morning.
The router then synced at 2500 or so and Interleaving was turned on the DS SNR was then set to about 10.
I then rebooted the router again in the afternoon and it dropped to about 2000 the SNR went up again.
I rebooted the router again today to see if things improve and now the sync has dropped to 1600 and the DS SNR is about 16.
Does anyone know what the problem could be, Before Sunday evening it was solid at 2900-3200 with only a max of 1 or 2 resyncs a day.
If it drops any more my data rate will be set to 1mb which is what I was on before I was Maxed.
The line has run fine with a datarate of 2500 and have downloaded at 300kb and have had 2.4 on the speed tests.
I am worried that my line will get slower and slower.
Could interleaving be causing it.
