10 GB Gaming !!
10 GB Gaming !!
:shock: Hi just checked my usage and it shows tha I have used over 10gb gameing.. now I know XboxLive is pretty popular in my house but 10GB!
Just a thought but does downloading demos etc from XBLive count 2ward gaming ?
Thanks..
10 GB Gaming !!
it depends what speed/package are you on?
10 GB Gaming !!
Hi thanks 4 the reply :
Premier 1
8mb adslmax
Pack/speed will only prob mean the amount that I could download BUT 10gb for gameing ?!?
10 GB Gaming !!
I would think so - a simple way to establish how the downloads have been classified is by looking at the whole picture - for example are your http downloads showing 10GB less than you would have expected?
