Images Search
aladdin
Images Search
UserGroup Moderator's Note
The original post in this topic was deleted by its author (a moderator at the time) as a reaction to significant differences of opinion with fellow Community moderators unconnected with this topic. Apologies are due to Aladdin staff that this left this post as a response to what is now a non-existent question. To remedy this the question was along the following lines:
Using Google Image search it is possible to gain access to unsuitable material on sites that eSafe would normally block. Are settings available which allow this loophole to be blocked?
Aladdin's response follows.
David (spraxyt)
Aladdin Response
eSafe does support the ability of blocking unclassified image search in Google.
Once a subscriber will change the Google SafeSearch Filtering to the least restrictive (Do not filter my search results) eSafe will block ANY image search. therefore, if there is an attempt to "bypass" Google SafeSearch, no image search will be allowed.
In the default eSafe configuration for ISP's this feature is disabled.
Cheers,
Asa
