DMT Tool blocked
DMT Tool blocked
Interestingly, tried to download the latest DMT tool from http://www.2cent.de/dmt/v8/dmt.zip
Blocked by eSafe?
B.
James
Re: DMT Tool blocked
Addon - This is a ADSL diagnostics tool which allows customer to tweak their connection performance.
Er, yes..
Homepage for the DMT tool here
B.
Fixes: 8
Yup.  I get the 'Access denied' screen from that site too.  The PlusNet screen invites me to Login to change settings to allow access - but goes nowhere?
Maurice
Fixes: 43
The originally mentioned URL is blocked, but when I use the classification checker it says:
The URL http://www.2cent.de/dmt/v8/dmt.zip is classified as
Not yet categorized or does not fit into any category
Does that imply 'not categorized' URLs are blocked by default?
David
David
Fixes: 43
Quote from: spraxyt
To answer my own question it would appear not since the official site is also not categorized, but that is accessible.
The URL http://dmt.mhilfe.de/ is classified as
Not yet categorized or does not fit into any category.
Huh
David
David
Not categorized zip file banned perhaps?
Maybe a test of a zip file in somebody's webspace which is also 'unclassified'?
aladdin
Aladdin Response
The site www.2cent.de ; was blocked because it's in the Known Spyware website list.This list is a  separate list not related to the URL db.
The URL check is related to the URL DB classification only.
We are analyzing the lists constantly and update the sites if necessary to avoid false positive
Asa
Fixes: 43
Thanks for that explanation. I'll add a note in the FAQs about this.
Are there any other 'hidden' lists? And is a tool provided so that users can check sites against them?
David
David
aladdin
Aladdin Response
In the original Spyware/Adware blocking message there is a link to eSafe WebWatch service.
In this link you can receive explanation regarding the sites being blocked (different from the URL classification).
Here is the direct link where you can test the
http://www.esafe.com/csrt/index.aspx
Asa
Fixes: 43
Thanks. I've added that link to the FAQ.
David
David
