Connection instability
Fixes: 8
Quote from: _CN_
Hi Maurice
you'll be back on when you disconnect and reconnect, thanks
Carl
Just done that.  Now having difficulty in keeping the session for more than 20 - 30 secs at a time.
Maurice
Moderator's Note: Topic split from its original location since it relates to a new issue. David.
Fixes: 8
Re: Aladdin being switched off 25/03
Connection seems to have stabilised again?  Seeing some odd times in tracert to plus.net.
C:\Documents and Settings\Administrator>tracert plus.net
Tracing route to plus.net [212.159.9.2]
over a maximum of 30 hops:
  1  883 ms  978 ms  904 ms  192.168.1.1
  2  389 ms    24 ms    21 ms  32.core.plus.net [195.166.128.32]
  3    20 ms    21 ms    39 ms  84.92.5.98
  4    21 ms    29 ms    35 ms  te2-2.pte-gw1.plus.net [212.159.0.186]
  5    33 ms    28 ms    37 ms  atm1-0.ptb-gw1.plus.net [212.159.1.89]
  6  712 ms  777 ms  794 ms  fhw-lb03.plus.net [212.159.1.145]
  7    60 ms    31 ms    47 ms  portal.plus.net [212.159.9.2]
Trace complete.
  1    <1 ms    <1 ms    <1 ms  192.168.1.1
  2    32 ms    23 ms    22 ms  32.core.plus.net [195.166.128.32]
  3    22 ms    21 ms    29 ms  84.92.5.98
  4    26 ms    26 ms    32 ms  te2-2.pte-gw1.plus.net [212.159.0.186]
  5    31 ms    28 ms    31 ms  atm1-0.ptb-gw1.plus.net [212.159.1.89]
  6    28 ms    32 ms    27 ms  fhw-lb03.plus.net [212.159.1.145]
  7    30 ms    29 ms    35 ms  portal.plus.net [212.159.9.2]
Trace complete.
Plusnet Alumni (retired) _CN_
Quote from: MauriceC
Maurice
I see from your RADIUS logs you seem to have had problems with keeping a connection prior to being put back onto the Aladdin trial, if this is going to 'muddy' the waters I'd suggest we remove you from the trial?
Regards
Carl
Fixes: 43
Re: Connection instability
The hop to your router initially had high pings too?
I got strange tracerts too. First try has large pings on hop 3. Repeat after a few seconds and again after a few minutes is normal.
C:\>tracert plus.net
  1    <1 ms    <1 ms    <1 ms  192.168.2.1
  2    37 ms    46 ms    41 ms  32.core.plus.net [195.166.128.32]
  3  260 ms  229 ms  245 ms  84.92.5.98
  4    37 ms    37 ms    37 ms  te2-2.pte-gw1.plus.net [212.159.0.186]
  5    47 ms    51 ms    43 ms  atm1-0.ptb-gw1.plus.net [212.159.1.89]
  6    46 ms    42 ms    47 ms  fhw-lb03.plus.net [212.159.1.145]
  7    42 ms    48 ms    42 ms  portal.plus.net [212.159.9.2]
Trace complete.
  2    52 ms    36 ms    37 ms  32.core.plus.net [195.166.128.32]
  3    41 ms    49 ms    41 ms  84.92.5.98
  4    38 ms    56 ms    38 ms  te2-2.pte-gw1.plus.net [212.159.0.186]
  5    57 ms    44 ms    44 ms  atm1-0.ptb-gw1.plus.net [212.159.1.89]
  6    43 ms    56 ms    48 ms  fhw-lb03.plus.net [212.159.1.145]
  7    59 ms    60 ms    52 ms  portal.plus.net [212.159.9.2]
Trace complete.
  2    37 ms    44 ms    41 ms  32.core.plus.net [195.166.128.32]
  3    46 ms    54 ms    35 ms  84.92.5.98
  4    36 ms    39 ms    37 ms  te2-2.pte-gw1.plus.net [212.159.0.186]
  5    43 ms    53 ms    44 ms  atm1-0.ptb-gw1.plus.net [212.159.1.89]
  6    41 ms    41 ms    42 ms  fhw-lb03.plus.net [212.159.1.145]
  7    43 ms    42 ms    43 ms  portal.plus.net [212.159.9.2]
Trace complete.
David
Quote from: spraxyt
When running traceroute at each hop the packet has to be punted to the CPU to be dealt with, the hop 84.92.5.98 is a Cisco 7609, at that time the router could have been doing large scale BGP convergence etc. (it also has transit and peering connections) however while its doing this the traffic through the box is not effected, which you would see by just running ping plotter.
Carl
Fixes: 43
Quote from: _CN_
… however while its doing this the traffic through the box is not effected, which you would see by just running ping plotter.
Thanks for that explanation. I ran pingplotter for 5 minutes and saw the effect you describe; pings to hops 3 and 4 show large variations but values after that (throughput) changed by no more than 1ms.
David
David
