PAYH trial domains
Kev_Mawson
PAYH trial domains
Hi
The long term plan is to let people use www.username.plus.com, but for the trial we can't do that.
So when we open this up, which domain do you think we should use...
username.inuk.com
username.plus-payh.co.uk
username.plushost.co.uk
Any other suggestions?
James
Re: PAYH trial domains
InUK is dated and may still have some legacy customers who will have used it in the past.  Plushost suggests hosting from Plusnet which just works imho.
Kev_Mawson
inUK is now fully on PAYH, and does have an handful of customers, so this will not cause any issues
Fixes: 5
I'd say plushost.co.uk personally.  Is the plan for f9 and fol customers to have the same one?  If so what happens where there is a clash of usernames?
Phil
Kev_Mawson
For the trail it will be the user name of the customers PAYH account so there will be no duplicates  Grin
Fixes: 5
OK, Thanks Kev.
Phil
plushost sounds like the best option to me ...
Fixes: 8
definitely username.plushosts.uk  seems the best option.
username.inUK.com  harks back to a previous product and serves little purpose.
username.plus-payh.co.uk perpetuates the vision of maintaining separate companies.
username.plushosts.uk    on the other hand starts to create a much more inclusive vision of the Plusnet offerings.
Kev,  I think that to fuly answer Phil's question on duplicate names, we have to look further than just the trial?  Timescales proposed by Ian are quite aggressive in getting this thing rolled to users?
Maurice
Kev_Mawson
Hi
The choice of domain for now is just for the trials, there is no talk of when we go live that new customers will be able to have this domain, although we are not going to take it away from customers who may want to keep that domain.
When we roll the service then customers will have what they have today meaning they will have username.plus.com, username.f9.co.uk
So there will be no duplications
Hope that clears things up a little more
