How should I use PAYH - re-register?
Fixes: 8
I was given a trial domain of elvin.plus-payh.co.uk which I didn't use because of the inability to unpack tar files.
This weekend, finally having some time to look at this and following the recent posting of the cron method I decided to have a go.
Unfortunately I found that cron is disabled in my account.
Should I continue using elvin.plus-payh.co.uk or do I need to start again so that I have username.plushost.co.uk? If I have to start again can I do this myself or does someone at Plusnet need to unpick what I already have? I already have an account on PAYH - I assume going through trials.plus.net would result in a new account being created.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Kev_Mawson
Re: How should I use PAYH - re-register?
Hi
This has now been enabled for you, you can continue using this account as you hosting space for your Plusnet account.
Fixes: 8
Thanks Kev - it will probably be tonight when I have another go.
