your high speed broadband service - value changed
- Re: your high speed broadband service - value chan...
20-08-2008 9:04 PM
i am on the premium gaming connection thingy and i am only just up the road from the exchange before i get moaned at by people with a 2mb connection.
my yahoo pop3 accounts have suddenly stopped working on outlook as well but i should probably post this somewhere else
any help would be much appreciated
many thanks
Andy
Re: your high speed broadband service - value changed
20-08-2008 9:19 PM
Quote from: martin2006
Too late!
You're bloody lucky! I DREAM of 2 Mbps speeds. Sometimes I wake up in the middle of one of those dreams and find the front of my pyjama trousers is moist.
20-08-2008 9:23 PM
andy
20-08-2008 9:26 PM
20-08-2008 9:42 PM
20-08-2008 10:32 PM
20-08-2008 11:17 PM
21-08-2008 11:28 AM
Quote from: spraxyt … and, the answer to the original question is that the 8000 kbps High-speed Broadband setting on the website has always really been 7150 kbps, the maximum IP Profile that BT assign for an 8128 kbps sync. So basically nothing has changed, it just says 7150 kbps now.
I would say interleaving been switched on mine dropped from 8128 to 7150 when it was activated
puddy
21-08-2008 5:19 PM
The 8000 & 7150Kbps profiles are the same. 7150Kbps is the highest BT profile, so we just mirror this.
Andy - That shows nothing wrong with your profiling.
24-08-2008 10:15 AM
now i do have another question which you may want me to start a new thread but i mainly use my connection for online gaming, mostly Battlefield 2, and wondered if there is anything i can do to improve my ping as a lot of the servers are overseas. my mate up the road gets pings of around 20, where as i get anything from around 30 at lowest and up to 80 for even relatively local servers. we are both on plusnet, and again to nip the comments in the bud, i am a sad individual who is obsessed with numbers and immature pc based activities.
many thanks
Andy
24-08-2008 11:42 PM
Since you are close to the exchange line stability is unlikely to be a problem for you so requesting that interleaving be turned off should reduce your pings to the circa 20ms level you mention your friend has. You can request interleaving be turned off by raising a ticket, or by clicking the icon in the website Connection Settings folder if there is one.
25-08-2008 4:43 AM
Modem Status
Connection Status Connected
Us Rate (Kbps) 448
Ds Rate (Kbps) 8128
US Margin 25
DS Margin 11
Trained Modulation ADSL_G.dmt
LOS Errors 0
DS Line Attenuation 63
US Line Attenuation 17
Peak Cell Rate 1056 cells per sec
CRC Rx Fast 667
CRC Tx Fast 42
CRC Rx Interleaved 0
CRC Tx Interleaved 0
Path Mode Fast Path
DSL Statistics
Near End F4 Loop Back Count 0
Near End F5 Loop Back Count 0
many thanks
Andy
25-08-2008 12:09 PM
Quote from: martin2006 Modem Status
Us Rate (Kbps) 448
Ds Rate (Kbps) 8128
US Margin 25
DS Margin 11
LOS Errors 0
CRC Rx Fast 667
CRC Tx Fast 42
Path Mode Fast Path
Yes, you already have interleaving off, your stats say Fast Path (red text) which means that. Having CRC errors against Fast but zero against Interleaved confirms that.
One anomaly in the stats is that they say Downstream Line Attenuation is 63dB. If that were true you would be syncing around 2Mbps and not the 8Mbps you have. Has your router always reported that figure - it makes me wonder if the router is a little dodgy?
25-08-2008 12:36 PM
the other question i was going to ask was is there a ping test i can do to see if my ping is high in bf2 cos of the servers i am on, i know my mate used to ping the bbc or something to test his.
thanks for you help
Andy
25-08-2008 1:10 PM
You can do a ping by opening a command window (Start->Run… type in cmd then click OK) and enter ping www.bbc.co.uk (or, of course, a different domain) at the chevron prompt. Enter exit to close the window.
