wifi issues
Jphugs
wifi issues
Hi all, (
I have been with plusnet for almost 3 years now and have been having trouble with my wifi and broadband stability for almost a year now. I am currently using the same router plusnet supplied me with 3 years ago (sagemcom router 2704n), I have spoken to plusnet several times of late with these issues and have never been given a permanent solution to the problem. Is this router old and fairly poor quality? and can I do anything with it to improve wifi? my wife runs an online business from home and decent wifi is crucial.
6 REPLIES 6
Jphugs
Re: wifi issues
my internet speed should be around 20mbps but I generally only get around 5mbps....could this be a router problem also?
Legend
Fixes: 255
Re: wifi issues
Welcome to the forums, @Jphugs.
Just an observation, but if you run a business online, you should be on a business package - PlusNets' T&C's make that fairly clear.
Also, for anyone to advise you, a little more detail is required - see the ADSL speed faults sticky towards the top of this board.
JayG
Fixes: 6
Re: wifi issues
Wifi isn't a perfect technology, and the 2704n router isn't the best Wifi router available, although mine is adequate for my needs using TP-link extenders to extend the range (also not 'perfect' technology though!)
Assuming both posters don't have similar problems using wired connections, it may be worth using an app like 'Wifi Analyzer' on a portable device to check the signal strength at different locations - changing router position and/or wireless channel can make a big difference.
Legend
Fixes: 255
Re: wifi issues
@JayG I don't have a problem, I was merely advising @Jphugs.Smiley
JayG
Fixes: 6
Re: wifi issues
Sorry @jab1 - eyes and brain obviously not fully focussed yet (hadn't noticed that first 2 posts were by same member! Embarrassed)
Fixes: 1,600
Re: wifi issues
Hi there. Welcome to the community forums.
Our tests aren't finding any issues and we can see your router in sync at 24mbps.
Would you be able to try a wired connection to your router? This will help narrow down where the problem lies.
If your speed is OK that way, then it's likely the issue lies with the wireless signal and further help can be found here: https://community.plus.net/t5/Plusnet-Blogs/How-to-boost-your-wi-fi/ba-p/1450193
If you're still having problems using a wired connection, please can you run a speed test at www.speedtest.btwholesale.com completing the further diagnostics?
