why do i get .5mb top speed????????
- Re: why do i get .5mb top speed????????
21-02-2011 9:07 PM
21-02-2011 9:20 PM
Post the results of a BT speedtest which will show your sync rate and IP profile: http://speedtester.bt.com
What is your plusnet IP profile set to: https://portal.plus.net/my.html?action=data_transfer_speed
21-02-2011 9:24 PM
Download speed achieved during the test was - 423 Kbps
For your connection, the acceptable range of speeds is 50-500 Kbps.
Additional Information:
Your DSL Connection Rate :800 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 500 Kbps
thats one of the best results...
Telephone number:
Phone exchange:
KILMARNOCK
Estimated line speed:
0.5Mb (This may System Date and Time
vary between 1Mb and 4Mb) - Checked on 2011-02-12 14:14:37
Current line speed:
0.5 Mb
LAN Settings
Date/Time February 21 2011 , 21 : 27 : 35 LAN MAC Address IP Address 192.168.2.1
Version Info Subnet Mask 255.255.255.0
Runtime Code version F5D7633-4Av1_UK_1.00.000 DHCP Server Enabled
Boot Code Version 1.0.37-5.15
Hardware Version V1.0J3 WLAN Settings
ADSL Modem Code Version A2pB015c6 Wireless Function Enabled
Serial Num 168-168-16888 WLAN MAC Address Mode
125 High-Speed Mode
Features SSID belkin54g
Firewall Enabled ESSID Broadcast Enabled
NAT Enabled Channel 11
UPnP Disabled Security WPA-PSK
ADSL Internet Settings
Type Interleave Default Gateway 195.166.128.243
Status No Defect Primary DNS Server 212.159.6.9
Downstream Upstream
Secondary DNS Server 212.159.6.9
Data rate 800 448
in 8.6 18.0
LAN IP Address
Output power 15.4 12.3
Default Gateway
Attenuation 63.0 31.5
Primary DNS Server
21-02-2011 9:27 PM
21-02-2011 9:30 PM
[Moderator's note by Jim (Oldjim) and we don't like shouting either - all caps removed ]
21-02-2011 9:36 PM
21-02-2011 9:37 PM
You are on a very long line (63dB line attenuation) so the chances of getting a faster connection are little to none. Your 800Kbs sync rate limits your data rate to 0.5Mbs hence your slow speed (the 1Mb to 4Mb speeds are an estimate and not a guarantee your speed will be between the figures quoted).
Are you connected to the master socket. If not, try that again and post the router stats again as they may improve, although probably not by much. Note the only bts of nfo we need are line attenuation SNR/Noise margin and sync rates for both upstream and downstream.
Have you also tried connecting to the test socket which is behind the lower removable part of the master socket. This will eliminate any local phone wiring which may be interfering with the signal.
I assume you have ADSL filters on all phones, modems, faxes and sky boxes?
21-02-2011 9:55 PM
22-02-2011 3:21 PM
03-03-2011 11:54 AM
03-03-2011 12:12 PM
Your profile looks good but your speed isn't very good. Your line is still dropping quite a bit so I wouldn't be surprised to see the profile go down again. Have a look here for some tips.
Jojo
