was told i was on adsl2+ but dont think i am ( PLEASE HELP )
- Re: was told i was on adsl2+ but dont think i am
03-06-2013 11:17 PM
Link Information
Uptime: 1 day, 0:10:40
DSL Type: ITU-T G.992.3
Bandwidth (Up/Down) [kbps/kbps]: 443 / 4.391
Data Transferred (Sent/Received) [MB/MB]: 126,79 / 560,44
Output Power (Up/Down) [dBm]: 12,9 / 0,0
Line Attenuation (Up/Down) [dB]: 28,5 / 48,5
SN Margin (Up/Down) [dB]: 17,8 / 9,0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 371 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 29 / 1.554
HEC Errors (Up/Down): 9 / 14.791
03-06-2013 11:47 PM
Quote DSL Type: ITU-T G.992.3
is "ADSL2" - see Wikipedia http://en.wikipedia.org/wiki/G.992.3
"ADSL2+" would be "G.992.5"
Quote Bandwidth (Up/Down) [kbps/kbps]: 443 / 4.391
You might want to ask Plusnet to uncap your upstream, as it should manage more than 443Kbps.
Re: was told i was on adsl2+ but dont think i am ( PLEASE HELP )
04-06-2013 6:47 AM
04-06-2013 6:59 AM
04-06-2013 1:02 PM
04-06-2013 1:04 PM
04-06-2013 1:09 PM
04-06-2013 1:31 PM
04-06-2013 2:00 PM
So why are they telling me different
04-06-2013 2:24 PM
I had a phone line fault and was moved to a new line from my cabinet to the exchange and since then I have never been able to connect as ADSL2+ only ADSL2, when on the previous line I would always connection as ADSL2+.
04-06-2013 4:02 PM
04-06-2013 4:11 PM
04-06-2013 4:20 PM
Maintenance -> Diagnostics -> Display detailed ADSL driver informations
If you do have this, click the [Display] button, and try and copy and paste the content of that window back in this thread (preferably using the "Insert code" # button when you are composing your reply).
04-06-2013 4:22 PM
04-06-2013 4:25 PM
only option i have is Diagnostics - Routing Table
