very slow browsing
- Re: very slow browsing
very slow browsing
06-04-2011 4:41 PM
my net speed for some sites seams completely constipated.
I tried pinging the affected sites which are showing ttl in the region of 250ms including pn. google remains at only 55ms and remains useable.
Pinging plus.net [212.159.8.2] with 32 bytes of data:
Reply from 212.159.8.2: bytes=32 time=49ms TTL=250
Reply from 212.159.8.2: bytes=32 time=52ms TTL=250
Reply from 212.159.8.2: bytes=32 time=47ms TTL=250
Reply from 212.159.8.2: bytes=32 time=46ms TTL=250
also some timeouts
Pinging 212.159.9.2 with 32 bytes of data: (PN)
Request timed out.
Reply from 212.159.9.2: bytes=32 time=43ms TTL=250
Reply from 212.159.9.2: bytes=32 time=42ms TTL=250
Reply from 212.159.9.2: bytes=32 time=41ms TTL=250
Ping statistics for 212.159.9.2:
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Approximate round trip times in milli-seconds:
Minimum = 41ms, Maximum = 43ms, Average = 42ms
Pinging bbc.co.uk [212.58.224.138] with 32 bytes of data:
Request timed out.
Reply from 212.58.224.138: bytes=32 time=36ms TTL=120
Reply from 212.58.224.138: bytes=32 time=35ms TTL=120
Ping statistics for 212.58.224.138:
Minimum = 35ms, Maximum = 36ms, Average = 35ms
I have rebooted but get the same slow speeds to these sites.
Ping statistics for 212.159.8.2:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Minimum = 46ms, Maximum = 52ms, Average = 48ms
Pinging google.co.uk [209.85.227.147] with 32 bytes of data:
Reply from 209.85.227.147: bytes=32 time=43ms TTL=55
Reply from 209.85.227.147: bytes=32 time=42ms TTL=55
Reply from 209.85.227.147: bytes=32 time=41ms TTL=55
Ping statistics for 209.85.227.147:
Minimum = 41ms, Maximum = 43ms, Average = 41ms
also some timeouts
Request timed out.
Request timed out.
Message 1 of 2
(539 Views)
1 REPLY 1
06-04-2011 5:20 PM
Hi Podman,
I don't see anything wrong with those results. The TTL is not the speed of the ping but what is called Time To Live. There are many references to what this means on the internet.
Jojo
Jojo
Message 2 of 2
(256 Views)
