upload speeds
- Re: upload speeds
upload speeds
11-07-2013 3:00 AM
Has anyone else had this issue or is it just me. Download speeds are pretty good getting between 10 to 14 mb but upload speed is horrendous.
BEST RESULT
d/l 15.43 Mb/sShare
up/l 0.38 Mb/sShare
server Ealing
CONNECTION GRADE ?
National GradeD- (23%)
Global GradeD+ (37%)
this was 6 days ago and now the result is
7/11/2013 1:58 AM GMT
11.45 Mb/s 0.35 Mb/s 66 ms London < 50 mi
is that good or poor
BEST RESULT
d/l 15.43 Mb/sShare
up/l 0.38 Mb/sShare
server Ealing
CONNECTION GRADE ?
Message 1 of 6
(1,238 Views)
5 REPLIES 5
Re: upload speeds
11-07-2013 7:44 AM
What speed is your router actually syncing at?
Message 2 of 6
(435 Views)
Re: upload speeds
11-07-2013 8:16 AM
Those upload speeds are fairly typical of a capped upload (just below 0.45Mb/s sync), if this is the case then Plusnet can uncap for you.
Call me 'w23'
Message 3 of 6
(435 Views)
Re: upload speeds
11-07-2013 2:21 PM
Hi eleyzaamina,
w23 is exactly right - I'll get the uncap order placed for you, should get you around 1Mb on the upload instead. It'll complete tomorrow, hope it sorts things out for you.
Message 4 of 6
(435 Views)
Re: upload speeds
11-07-2013 9:18 PM
Thanks all.
(ReedRichards) What speed is your router actually syncing at?
sorry how do I check that.
Message 5 of 6
(435 Views)
Re: upload speeds
12-07-2013 12:47 PM
If you're using the technicolor router we send out, just log in to it at http://192.168.1.254 - username is admin and the password is the router's serial number on the sticker on the bottom (starting with the letters CP). Once you're logged in click on the broadband section on the left and it should give you the stats in the main page.
Message 6 of 6
(435 Views)
