upload speed
- upload speed
upload speed
15-03-2010 5:44 PM
I moved to adsl2+ a while back and then got my upload speed uncapped. I have recently started more gaming online but sometimes my connection is dropping, never really had a problem before. I am wondering whether I can get some sort of cap put back on my upload speed to see if this helps?
I am getting about 975 at the moment but I have noticed than my upstream snr can be as low as 3db but am not sure what is normal for upsteam snr?
Any help appreciated
Message 1 of 8
(1,242 Views)
7 REPLIES 7
Re: upload speed
16-03-2010 2:34 AM
The 21CN DLM includes 3dB as an available target noise margin so it is reasonable to assume it expects such values to work. However that might be with interleaving on - have you got that turned off to improve your pings - your upstream sync speed suggests it might be off?
If the DLM detects excessive numbers of errors or disconnections it should increase the target noise margin within a few days. How long is it since the problems started?
David
Message 2 of 8
(690 Views)
Re: upload speed
16-03-2010 3:04 PM
Has been happening for a few weeks.
Does not happen all the time but sometimes the first time I go onto a server the connection drops...
Message 3 of 8
(690 Views)
Re: upload speed
16-03-2010 8:30 PM
Here are my router stats just now.
Message 4 of 8
(690 Views)
Re: upload speed
16-03-2010 8:35 PM
My gut feel is that you are losing sync due upstream errors with the low noise margin possibly when first connecting to the server and there is a burst of high speed traffic
Message 5 of 8
(690 Views)
Re: upload speed
16-03-2010 8:39 PM
do you have interleaving off?
Message 6 of 8
(690 Views)
Re: upload speed
16-03-2010 9:38 PM
I have the same gut feeling about when I first connect to a server.
I have never asked for interleaving to be turned off but I believe it may well be turned off but not sure how I check?
Message 7 of 8
(690 Views)
Re: upload speed
16-03-2010 9:40 PM
You could try downloading and running RouterStats.
That can tell you and a lot more.
Message 8 of 8
(690 Views)
