up speeds
- up speeds
up speeds
22-02-2012 2:52 PM
I get about 3.77mbps down and 0.18mbps up, previously I had about 4mbps down and 0.35mbps up,I know that up speeds are not all that important but when sending longish E-mails it does annoy.
By the way it is a new filter and router ,Thomson from PN.
Re: up speeds
22-02-2012 3:43 PM
Are the speed results via wired or wireless?
Jojo
Re: up speeds
22-02-2012 7:30 PM
Re: up speeds
22-02-2012 7:34 PM
If the upload is OK like that and your router is a v8 (the version is on the label underneath) JoJo will send you a replacement router (the older v7) which doesn't have the same problem.
Re: up speeds
22-02-2012 9:21 PM
Re: up speeds
22-02-2012 10:52 PM
Re: up speeds
22-02-2012 10:55 PM
Re: up speeds
23-02-2012 10:25 AM
How did you get on with that?
Jojo
Re: up speeds
23-02-2012 10:31 AM
Re: up speeds
23-02-2012 12:03 PM
Re: up speeds
23-02-2012 10:47 PM
I tested the speed wireless and got
3769kbps 173kbps
then I hard wired it and got
3765kbps 368kbps
then I tried the old router and got
3769kbps 366kbps.
I have left the old router on
I now hope the old router stays OK. One thing I do find baffleing is why am I having this problem with a brand new router, a fault which Jelv recognised as a fault with this type of router,if this is true why does PN send them out to people that are already having problems.STRANGE ???. Ted.
Re: up speeds
23-02-2012 11:49 PM
Re: up speeds
24-02-2012 12:52 AM
Re: up speeds
11-04-2012 6:42 PM
With PN speed tester which seems to give the correct results and says it doesnt and the BT tester which should give correct speeds and doesnt ,I am fast getting past careing ,please can some one give it a bit of a push. After all I am a very very very old customer in more ways than one. Ted
Re: up speeds
11-04-2012 9:09 PM
I see from your ticket that you say all the lights on the technicolor router are green apart from the internet light. This would indicate that you need to enter the username and password into it. Can you do that and see if it connects?
Jojo
