unstable max could a rep look at these 2 tickets
- Re: unstable max could a rep look at these 2 ticke...
06-03-2010 9:50 AM
32358257 most recent
29841099 original
Last time openreach suggested swap to new 100 pair copper cable as I am on a aluminium cable but got put on fixed profile
my atten 60db new line in building on the 100 pair 48db atten currently synced over 2500 more than my old aluminium line at 4032 target snr 12.
would appreciate some input and help in the swap.
Since moving back off fixed 2000 sync was 3264 with target 6 snr now line 1440 with a target ot 15 snr
Good line using a dg834 v 3 ( no need for wireless)
old line using a 2700hg-b
Hope a rep can help
latest stats from 2700hg-b just did a retrain of adsl during the day
DSL Down Up
Current Rate: 1824 kbs 448 kbs
Max Rate: 1824 kbs 692 kbs
Current Connection:
Current Noise Margin: 15.0 dB 13.0 dB
Current Attenuation: 59.3 dB 31.5 dB
Current Output Power: 17.4 dBm 11.9 dBm
I will do the same and post from the 834 on the other line
From dg834
ADSL Link Downstream Upstream
Connection Speed 4032 kbps 448 kbps
Line Attenuation 48 db 13.5 db
Noise Margin 11 db 18 db
29841099 original
Hope a rep can help
DSL Down Up
Current Connection:
From dg834
Message 1 of 7
(1,283 Views)
6 REPLIES 6
Re: unstable max could a rep look at these 2 tickets
08-03-2010 2:34 PM
The support staff are not reading the tickets correctly and I am playing Ticket ping pong
I would appreciate an input from a rep.
Message 2 of 7
(557 Views)
09-03-2010 1:52 PM
I believe Matt has been helping you out and replying over on ThinkBroadband?
Message 3 of 7
(557 Views)
10-03-2010 11:08 AM
Chris thanks for the reply
I think Bob may be looking at it again
Message 4 of 7
(557 Views)
12-03-2010 1:44 PM
Openreach has just left after a pair swap
DSL Down Up
Current Rate: 3712 kbs 448 kbs
Max Rate: 3712 kbs 956 kbs
Current Connection:
Current Noise Margin: 15.0 dB 22.0 dB
Current Attenuation: 47.6 dB 27.0 dB
Current Output Power: 19.1 dBm 11.9 dBm
Just a bit of a difference
DSL Down Up
Current Connection:
Message 5 of 7
(557 Views)
12-03-2010 10:12 PM
latest stats
DSL Down Up
Current Rate: 4672 kbs 448 kbs
Max Rate: 4672 kbs 980 kbs
Current Connection:
Current Noise Margin: 6.0 dB 23.0 dB
Current Output Power: 19.0 dBm 11.9 dBm
DSL Down Up
Current Connection:
Message 6 of 7
(557 Views)
13-03-2010 11:52 AM
latest bt speed test
Download speedachieved during the test was - 4688 Kbps
Additional Information:
Your DSL Connection Rate :5920 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 5000 Kbps
this was on a line the struggled to get a sync above 1800 is yesterday well done openreach
Message 7 of 7
(557 Views)
