unable to access hotukdeals
New to PlusNet as of yesterday - can access all our usual websites except for hotukdeals.com (using Opera - could not locate remote server). Is this just us or is it a general problem - this is a vital site for my wife!
16 REPLIES 16
Re: unable to access hotukdeals
Just tried it. Straight in.
Fixes: 886
working fine here too, used often in our house and I'd get it in the neck too if it wasn't working Wink
Fixes: 62
are you using a Plusnet router or your old one
Having said that I can't connect to them either using Plusnet DNS
Using tracert it is a DNS lookup problem
Changed to Google DNS and problem solved
Fixes: 415
A bit slow but I got there.
Customer and Forum Moderator. Windows 10 Firefox 74.0.1 (64-bit)
Life is tough enough without adding Linux into the mix.
Same problem here, not been able to access it for 2 days now.
Fixes: 62
As a quick get around I suggest changing the DNS servers on your computer to use Google as the first one
Fixes: 353
Hi guys.
We're aware customers are having issues with accessing hotukdeals
At the moment we're investigating further to find out what's the issue but as soon as we know more we'll update this thread.
Apologies for any inconvenience caused.
 Matthew Wheeler
Fixes: 136
Quote from: Oldjim
Does seem to be DNS related:
~$ dig hotukdeals.com @8.8.8.8
; <<>> DiG 9.3.4-P1.2 <<>> hotukdeals.com @8.8.8.8
; (1 server found)
;; global options:  printcmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 60866
;; flags: qr rd ra; QUERY: 1, ANSWER: 5, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
;hotukdeals.com.                        IN      A
;; ANSWER SECTION:
hotukdeals.com.        299    IN      A      104.20.14.114
hotukdeals.com.        299    IN      A      104.20.16.114
hotukdeals.com.        299    IN      A      104.20.12.114
hotukdeals.com.        299    IN      A      104.20.13.114
hotukdeals.com.        299    IN      A      104.20.15.114
~$ dig hotukdeals.com @212.159.6.10
; <<>> DiG 9.3.4-P1.2 <<>> hotukdeals.com @212.159.6.10
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 29025
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 0
Fixes: 353
Hi guys.
This should be fixed now. Is anybody still having issues?
 Matthew Wheeler
Fixes: 415
Loads much quicker now for me.
It's working here on our end now. Thanks for fixing this!
Many thanks to everyone for such prompt and helpful responses.
This is the first time I have ever tried posting and assumed there had been no response, not realising that I had been logged out after 60 minutes! Apologies to all concerned for apparent rudeness.
I was just looking up how to change my DNS server, as recommended, when my wife told me that hotukdeals was back on - all is well again!
Very impressed. Smiley
Quote from: Matthew
Hi guys.
I am still "having issues" (fiber).
Fixes: 62
You are not posting from a Plusnet connection but from your university - is this where you are having the problem
