udp_flood TG582n
- Re: udp_flood TG582n
udp_flood TG582n
10-04-2013 9:13 PM
Is it possible to deactivate udp_flood defence for a short while or even set the amount of packets, i can't alter or look at the rule for this in the gui, can this be done via telnet ect.
Message 1 of 2
(2,473 Views)
1 REPLY 1
11-04-2013 10:22 AM
We suspect this is disabled if you turn the firewall off in the router's GUI, please let us know if that works?
Message 2 of 2
(296 Views)
