two wee tv's
tosher
two wee tv's
Help folks, just signed up with plusnet broadband. Two wee t'v's not on bottom right hand of screen, so can't tell if logged on.
6 REPLIES 6
Fixes: 1,483
Re: two wee tv's
Welcome to the forums tosher Smiley
When you say you've just signed up, have you activated today or just requested the service?
Oldjim
Resting Legend
Fixes: 63
Re: two wee tv's
I think you are going to need to give a bit more information.
Are you using a Plusnet supplied router or a USB modem
tosher
Re: two wee tv's
Hi folks, I activated broadband on monday with plusnet modem.(thomson Gateway)
Oldjim
Resting Legend
Fixes: 63
Re: two wee tv's
I think I understand.
You have previously used a dial up or USB modem connection.
With the router you are always connected to the internet and when your computer can see the router there will be a Network (Internet Access) Icon in the bottom right corner you will not see the two little TV screens although normally the Network Icon is a little TV. It may however be hidden by default
Fixes: 1,483
Re: two wee tv's
Well if you're posting from your PC I think we can assume you are connected OK - you're certainly posting from a PlusNet IP address Smiley
What version of windows are you using?
In XP you would need to go Start > Control Panel > Network Connections  There should be a connection showing as connected.
Right click that and select properties, at the bottom you should see a tick box for 'Show icon in notification area when connected', tick that and they will appear.
Vista will probably be similar.
HTH
tosher
Re: two wee tv's
Sorted folks, thanks a lot.
Tosher
