to reboot or switch off/on
- to reboot or switch off/on
Re: to reboot or switch off/on
09-05-2009 5:10 PM
Many thanks for your attention
Rob
09-05-2009 5:55 PM
See if you can get RouterStats running http://www.vwlowen.co.uk/internet/files.htm ; also read the FAQ (I think Q4 applies)
Also have a read of this http://community.plus.net/forum/index.php/topic,76116.0.html which may help with setting up.
(Just in case, do you have a spare filter & access to another router?).
09-05-2009 8:48 PM
Rob
09-05-2009 10:05 PM
10-05-2009 11:57 AM
After restarting the router the sync speed is lower at 6976 but the SNR is very steady at 11.9.
I am back over the other side of the room now; wireless and back to my un-corded phone (I need the answer phone on).
My plan is to leave well alone over the next week and see if I can get the tree pruned.
Best wishes.
Rob
10-05-2009 12:40 PM
That slight drop in sync speed isn't anything to write home about, it will still give you a 6M profile and things may be more stable, but I would suggest you leave the modem/router on 24/7 now. Your current Target SNRM seems to be 12dB, and if your line is stable this may come down and so you may achieve higher sync speeds in the future.
10-05-2009 12:54 PM
Cheers, Rob
16-05-2009 11:03 AM
I gave up on routerstats ( could't get it to make any sense) but did get DMT working.
Thursday AM I was at home and ran DMT from 10ish after a 4am power up. Everything was nice and stable with a 11.6 snr margin, little variation, and a 7104 sync. (screen shot 1 below)
At around 11 I was on the net and lost sync. Powered off and resynced. OK for a while, then lost sync again. I had that morning been checking how old my router and filters were (18mths) so I had decided to buy a new filter. As I had lost sync I powered down the router, switched off the lap top and went to buy a new filter. Came back, plugged it in,with a fixed telephone line, and was then syncing at 7680 with 8.3 snr margin that was moving around somewhat. (screen shot 2 below).
Brilliant. New filter was obviously needed. A while later I decided to plug my other phone back in and unplugged the router my mistake. Restarted the router and came back at 9.1 with very little variation (screen shot 3). This continued through the after noon/evening
Yesterday, though, there were loads of errors (stupidly no shots) after leaving the router on all night. This continued all day. Turned off router last night and this morning back on, Sync of 7840 and snrm 9.1 which dropped to 8.6.
Decided to try old filter again. Sync of 7744(screen shot 7 & and steady 9 snrm.
So, my question is, what happened. Was it the filter, or when I lost sync was it the exchange, or something completely different.
Best wishes, Rob
16-05-2009 1:09 PM
Ha, reading through your text I thought, this might be a bit tricky to deduce, but once I started looking at the graphs, different kettle of fish. DMT is so much better for bits/tone stuff.
If you hadn't changed filters already, I'd have promptly said try another, but as you have, considerations are different. There are two noticeable things here.
The Upstream bits/tone isn't right. I can't remember if you said you were using a cordless phone. If so, unplug the phone, switch it and the base station off, and do another DMT grab.
The fact that the performance didn't change much when you plugged the old filter back in suggests it's probably OK, the new one may be marginally better.
The fact that the noise plots are virtually flat, except the one where you first plugged the new filter in, but ok later with that filter, suggests it certainly an intermittent problem, but is it connection or interference?
Was there possibly any appliances switched on at that time, which aren't always on?
If you are not using a cordless phone, then you need to borrow/try another router ideally one that supports DMT, because we need to prove that the Upstream bits/tone is not a router problem before trying to report a fault, if it's not something of yours causing this. Reporting a fault under current circumstances will get no where, you'll be told it's all within expected performance and possibly get your Target SNRM raised to try and eliminate any disconnects, this will result in slower speed!.
16-05-2009 1:37 PM
I have no idea about bits/tone. This is a realm I have not yet entered No idea what it should look like. I think I can borrow a router from my daughter. Will try that over the week end with different combinations. ie ethernet, filters etc.
Out for the rest of the day, but will leave router and laptop on and see what happens.
Regards, Rob
16-05-2009 3:16 PM
DMT obviously plots the first 31 tones in green which is why the first part of the DS tones is in green, and that what confused me. Oh well can't be right all the time!
The plotting problem may be due to something in the DMT ini file, we might look at that later.
We'll see what happened to the noise when you get back.
18-05-2009 3:41 PM
I'm afraid everything went a bit pear shaped over the weekend (life stuff) so I was not able to get near replying until last night/ early morning,but everything had crashed. Gather there was a but of a problem with the network.
Anyways, things are a generally stable but , I see my bt profile has gone up another 500kbps from 6 to 6.5, so I'll have to ask james to give it a nudge. (Shall I open another thread, or will he pick it up from here do you think,) and then start monitoring again.
Cheers, Rob
18-05-2009 8:45 PM
18-05-2009 10:04 PM
Rob. Back to monitoring. Will be interested to see waht happens next.
Rob
19-05-2009 9:47 AM
