thomson tg585v8 router
- thomson tg585v8 router
12-06-2012 4:47 PM
My speed is good. But web keeps droping out.Or ie9 cant work.
Is this the router every thing else has been checked.
How can I check it or is there a better router out there.
Speeds DLoad 5.5 Upload 0.35
Message 1 of 5
(1,010 Views)
4 REPLIES 4
Re: thomson tg585v8 router
12-06-2012 5:00 PM
Hi mumbietaxi,
Your line looks solid. Are you connected wirelessly? Have you tried another browser? I personally find IE9 very frustrating at times (the polite version)
Jojo
Jojo
Message 2 of 5
(478 Views)
13-06-2012 11:07 AM
Thank you for prompt reply.
Connection is vie Ethernet cable
Which router would you advise me to go for ?
How do I get rid of ie9 and replace with ie8.
Dos not show up in control panel for me to uninstall.
I too dont like it.
I too dont like it.
Message 3 of 5
(478 Views)
13-06-2012 11:22 AM
You should be fine with the router you've got to be honest, aside from that I've seen a few people on these forums talking about one of the Billion routers - I think it's the 7300N? If you drop a post in the hardware forum you should get a few answers on that one.
With regard to browsers, rather than using Internet Explorer you could try firefox or chrome? I've used both, personally prefer chrome at the moment. It's quite a bit faster than anything else I've used. That way you don't need to worry about uninstalling IE 9
Message 4 of 5
(478 Views)
15-06-2012 11:24 AM
Thank you will do
Message 5 of 5
(478 Views)
