thinking of changing broadband tarrif
mac
hi to all
i am on broadband plus and was thinking changing to broadband extra am in market 3 zone.
will i lose my referrals, my next bill is due 11/11  when will it be best to change, anything else i need to know
many thanks in advance
10 REPLIES 10
pjmarsh
Fixes: 20
Re: thinking of changing broadband tarrif
Hi
Referals will be kept.  You can change your package at anytime and it will take place on your next billing date.
Phil
mac
is there any charges for moving
VileReynard
Fixes: 20
No - they will put you on the new tariff on 11/11.
The accounting system can't handle mid-period transfers.
mac
once i change do i understand i cant change back . one last question,  do i enter into a year contract even though i been with plusnet for many years, thanks
pierre_pierre
you can change between the new product once a month, and if you are on one of the older product they will let you have a trial on the new and switch back if it isnt to your liking
mac
how long is a trial
Oldjim
Resting Legend
Fixes: 63
AFAIK 1 month
pierre_pierre
but ask on here before doing a ticket
mac
thanks
jojopillo
Hi mac,
As pierre_pierre said you can try the newer package for a month and go back if it doesn't suit you.
Jojo Smiley
