the plusnet safeguard
john65
the plusnet safeguard is not working i keep tuning it off but i still cant  get on the sites i need
2 REPLIES 2
30FTTC06
Fixes: 4
Re: the plusnet safeguard
So it ses... http://www.plus.net/help/broadband/how-to-use-plusnet-safeguard/
"Once your broadband service is ready, go to the Plusnet SafeGuard control panel and click the ON/OFF button at the top of the screen.
Next, switch your router off and on again. After 2 hours, Plusnet SafeGuard will start filtering content.
If you want to switch it off, follow the same steps and after 2 hours you’ll be able to browse as normal."
Mustrum
Fixes: 77
It may depend on what sites you are trying to get to. There have been problems getting to betting sites due to the IP addresses being used. Which sites are you trying to get to?
