tecnicolor tg582n router
- Re: tecnicolor tg582n router
24-07-2013 7:45 PM
recently ive encountered a number of occasions when Ive lost internent connections when this happens my ethernet/ internet and wireless lights start flashing ,I then get a message from the troubleshooter to allow a fix when I go through to process of fixing it says my wiring is ok and to switch off and on my router this seems to correct the problem .I have raised a ticket on a previous failure and been told theres no fault with my line but
what Im asking could there be a fault with my router ,and do I need a relacement
Message 1 of 4
(830 Views)
3 REPLIES 3
24-07-2013 8:04 PM
Yes because that £45 router is as much use as a block of cheese with ethernet cables plugged in to it.
Send it back get your £5 back and get a BT Home Hub from ebay, problem solved.
Message 2 of 4
(394 Views)
24-07-2013 10:27 PM
Unfortunately the routers dont have the best of reputation
Message 3 of 4
(394 Views)
25-07-2013 1:38 PM
thanks all for your advice, after reading a number of post this router seems to be causing a number of issues ,hopefully plusnet will take note and issue a more reliable router , after all it might cost a little more but the saving for plusnet in attending to solving problems and replacing routers would surely outweigh any additional cost.
Message 4 of 4
(394 Views)
