sync dropping every few minutes.
davyando06
Can any 1 help cuss the guys at plusnet ant got a clue, the bt engineer has been out, again, and still same. Where I live now I can only get adsl. At random times of day the modem misses and reboots itself, it keeps going and going for no reason and then starts up as normal. Has any1 had these problems cuss it started about 5 month's ago and still happens now.
3 REPLIES 3
Fixes: 168
Re: sync dropping every few minutes.
Quote from: davyando06
Are you rebooting the router or is it rebooting itself?
I've just had a look over the ticket and from what I can see we've been investigating this as a dropping connection, but if the router is rebooting that's something else altogether.
 Chris Parr
 Plusnet Staff
davyando06
The router re boots itself randomly, sometimes every 3 min but mostly every 8 min. It's when the wife goes on Facebook and I'm on ps3. I've reset everything to factory settings but no joy.
Is it when a certain device connects to your router when it does this? It may be worth disconnecting all devices connected to your router(ethernet and wireless) and then connect them one by one to see if it's a specific device causing this.
