switching off broadband modem
- switching off broadband modem
24-03-2009 10:22 PM
Re: switching off broadband modem
24-03-2009 10:59 PM
As long as you dont rebboot loads of times in a short period of time then the dslam(exchange will not blow its tiny brain thinking you have a line fault)
The reason i ask for the router stats is if your on a long line and have a low sync then turning your router on(syncing) at night time will give a lower sync speed than if you did it midday which if your on a long line you could cause your ip profile to drop losing 500kbps-1000kbps(1mb) speed.
24-03-2009 11:14 PM
24-03-2009 11:23 PM
25-03-2009 12:03 AM
When you think about it, there are probably lots of things left on/plugged in even when the house is empty for a short while...
TV, washing machine, fridge freezer, clock/radio, microwave, any thing else with a clock/timer in it. The most safety concious of us could unplug everything every night. Not very practical.
A working smoke alarm could help save lives but the rest is, most likely, down to luck - or lack of it.
Forum Moderator and Customer
25-03-2009 12:14 AM
25-03-2009 12:41 AM
I know my parent's use to make such an effort to ensure the TV. etc is switched off at the wall because of a fire hazzard but never the video recorder as they didn'rt want to have to reset the clock each day. Of course, the kettle was never unplugged any night
25-03-2009 1:27 AM
It would be quite an expedition to switch off the TV, DVD & VHS
If I wanted to switch off my PC (which for some reason uses two multi-socket extensions plugged into separate sockets in the ring main, each with a few multi-way adaptors for good measure,
I would have to allocate at least an hour to reach the inaccessible sockets.
25-03-2009 7:55 AM
Back to the OP' s question - It MIGHT result in a lower sync speed at switch on, but as ASBO has implied, if you post your ADSL line stats (Downstream & Upstream) we can make more informed comment.
25-03-2009 8:33 AM
26-03-2009 7:40 PM
Now Anotherone asked about my upload and download speeds. Those are 3172mbps down, 375mbps up. Router attention?? Synch speed. Apart from 'attention' prebably being 'attenuation', where do I find that?
26-03-2009 9:03 PM
Quote from: gbhall Now Anotherone asked about my upload and download speeds. Those are 3172mbps down, 375mbps up. Router attention?? Synch speed. Apart from 'attention' prebably being 'attenuation', where do I find that?
Take a look here.
27-03-2009 7:25 AM
29-03-2009 10:55 AM
DOWN UP
Sync 4224 448
noise margin 9.1 23.0
attenuation 42.0 24.0
power 19.6 11.9
Got the error stats anyway 924 in 76510464 or 1.3 x 10minus6
Enough to advise on powering off now?
edit : error when keying last line : power up
[Moderator's note by Adie (Adiewoo): Full quote of preceding post removed, as per Forum Rules ]
29-03-2009 4:18 PM
If you have a check, make a note of time and noise margin say hourly from about 6pm BST until as late as is convenient, at least 11pm ish, and post the data.
On a seperate note, those stats are not as good as they ought to be, I'm guessing we might see several dB variation in noise margin probably down to internal wiring issues, alternatively this may be due to poor quality filter(s). (Also there maybe a misreporting of that US power, it should be about 12, nothing related to wiring or filters).
So question, what type of Master socket do you have, is it a NTE5, the one with a hoizontal split 1/2 way down? (see attached, size is 85x85mm approx.) What's the logo on it?
Do you have fixed extension wiring and sockets and how many, and where is the router plugged in, and what other devices are plugged in and if a sky box or similar, is it plugged in via a filter? What type of filters fo you have? I think that covers it, sorry about the long list.
Edit: added approx. to dimensions to satisfy a pedant.
