? stuck bras profile
- ? stuck bras profile
06-12-2011 12:08 PM
I normally only have 2mb connection however over a month ago my connection became unstable possibly due the demolition of old houses on the estate causing interference. This has now stabilised but I am stuck at 1mb despite having a reasonable sync speed for 2mb. When the connection became unstable my dslam vendor id also changed from Thomson MultiMedia Broadband to Infineon and since that change I have had 1mb permanently. 3 weeks ago I had a few instances of 2 or so hours where I would get 2.3mb which does not fit with a bras profile for the sync speed I had of approx 2500kbps. I have been stuck at 1mb for approx 3 weeks now. My sync speed is actually slightly higher since the change of dslam approx 2600 as opposed to 2300 before.
Any help would be appreciated
Here are stats:
DSL Connection
Link Information
Uptime: 4 days, 13:00:06
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 2,656
Output Power (Up/Down) [dBm]: 12.5 / 17.0
Line Attenuation (Up/Down) [dB]: 31.5 / 59.0
SN Margin (Up/Down) [dB]: 14.0 / 7.0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 4 / 0
FEC Errors (Up/Down): 82 / 398,884
CRC Errors (Up/Down): 82 / 2,074
HEC Errors (Up/Down): 53 / 1,593
Estimated line speed:
Not recorded (service activated before we introduced estimates).
Current line speed:
1 Mb
FAQ
Test1 comprises of two tests
1. Best Effort Test: -provides background information.
Download Speed
862 Kbps
0 Kbps 4000 Kbps
Max Achievable Speed
Download speed achieved during the test was - 862 Kbps
For your connection, the acceptable range of speeds is 1200-4000 Kbps.
Additional Information:
Your DSL Connection Rate :2656 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 2343 Kbps
Upload Speed
366 Kbps
0 Kbps 448 Kbps
>Upload speed achieved during the test was - 366 Kbps
Upstream Rate IP profile on your line is - 448 Kbps
This test was not conclusive and further testing is required.This might be useful for your ISP to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
Please visit FAQ section if you are unable To understand the test results.
Here are stats:
DSL Connection
Link Information
Current line speed:
1 Mb
FAQ
Download Speed
862 Kbps
0 Kbps 4000 Kbps
Upload Speed
366 Kbps
0 Kbps 448 Kbps
Message 1 of 4
(1,169 Views)
3 REPLIES 3
Re: ? stuck bras profile
06-12-2011 1:37 PM
That caught my attention straight away, as I suspected it's because you've been moved from a 20cn (up to 8mb) to a 21cn (up to 20mb connection)
I'd suggest we reverse that for you. I just need to make you aware though that the process for that can take 5 working days and may involve some down time on the day the change is due to occur.
Quote my dslam vendor id also changed from Thomson MultiMedia Broadband to Infineon
Message 2 of 4
(430 Views)
06-12-2011 1:40 PM
Thanks very much for the reply. That would be great if thats possible.
Much appreciated
C Cairns
jim:quote
Much appreciated
C Cairns
jim:quote
Message 3 of 4
(430 Views)
06-12-2011 1:52 PM
Message 4 of 4
(430 Views)
