stable at 4.5 but fixed at 3.5
the_groundsman
Stats below. According to the portal my speed is set at 3500 kbps. Is that what I should expect given the actual connection speed is nearly 30% higher?
System Up Time 15 days 01:48:25
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 3691101 5886988 0 355         2296 14 days 07:46:11
LAN         100M/Full 0         0               0 0              0      15 days 01:48:05
WLAN 11M/54M 6472344 4176968 0 2597 410 15 days 01:48:25
ADSL Link Downstream Upstream
Connection Speed 4512 kbps 448 kbps
Line Attenuation           40.5 db  23.0 db
Noise Margin           10.0 db         23 db
2 REPLIES 2
itsme
Re: stable at 4.5 but fixed at 3.5
jojopillo
HI the groundsman,
At the moment the sync rate you have will only get that profile. I do reckon we could get a little more out of your line though. Are you using an extension socket/cable at all? Can you plug into the test socket for me so I can run some more checks?
Jojo Smiley
