speed problem
- Re: speed problem
speed problem
10-05-2013 1:13 PM
Looking for a bit of advice and possibly help from Plusnet staff.
First the background, ever since joining Plusnet my download speed has been about 4Mb which with an attenuation of about 30db I realise is quite low. I have accepted this as I think I knew the answer, following some building work my telephone extensions, including where the router is connected, were wired in non telephone cable (alarm!)
This week I decided to improve matters and installed an ADSL nation faceplate to the master socket, moved the router to that point and used homeplugs to get to the PC. The results are not good.
I will post the router stats at the bottom of this post, but it is syncing at 3023 Kbs which has not changed in the 2 days it has been in sync, the SNR is 29.5 which I realise is having some effect but using a corded phone on a quiet test reveals no noise at all.
Logging in to the member centre shows my line speed at 2.6Mb.
Running the BT speed tester gives a line speed of 2.5 and an IP profile of 2.66 with a max achievable of 4Mb.
Unfortunately before installing the face plate I did not check the router stats so it is quite possible that it was already syncing round about the 3Mb.
I would welcome any thoughts and help.
Link Information
Uptime: 1 day, 23:40:12
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 976 / 3,023
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 145.00
Output Power (Up/Down) [dBm]: 12.0 / 20.5
Line Attenuation (Up/Down) [dB]: 16.0 / 31.0
SN Margin (Up/Down) [dB]: 4.5 / 29.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 763 / 20
CRC Errors (Up/Down): 763 / 0
HEC Errors (Up/Down): 127,722 / 0
Incidentally as soon as I reconnected the router the HEC errors showed 127,000.
Link Information
Message 1 of 7
(932 Views)
6 REPLIES 6
Re: speed problem
10-05-2013 1:18 PM
I'd suspect a 'Banded Profile': http://www.plus.net/support/broadband/speed_guide/broadband_terminology.shtml#bandedProfiles
Call me 'w23'
Message 2 of 7
(451 Views)
Re: speed problem
10-05-2013 3:00 PM
Hi plustrev,
I've placed a SNR reset on your line as your speeds are currently restricted due to a bout of disconnections recently. Your line does now however appear to be very stable so the SNR reset should help.
This usually takes around four hours to take effect, let me know how you go.
Message 3 of 7
(451 Views)
Re: speed problem
10-05-2013 3:08 PM
Hi Chris, thanks for that.
It has already taken effect, my connection just dropped out and when reconnected it is syncing at about 14000Kb
Message 4 of 7
(451 Views)
Re: speed problem
13-05-2013 7:56 AM
Afraid I still need a bit of help on this.
Since the SNR reset on Friday I have been synching at more than 14Mb (currently more than 15Mb) and the BT speedtester shows a profile of 13Mb but the download speed is only 2.5Mb.
I think perhaps the Plusnet profile is stuck on 2.6? Thanks for any help.
1. Best Effort Test: -provides background information.
Download Speed
2.49 Mbps
0 Mbps 21 Mbps
Max Achievable Speed
Download speedachieved during the test was - 2.49 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 13.68 Mbps
Upload Speed
0.84 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.84Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
Download Speed
2.49 Mbps
0 Mbps 21 Mbps
Upload Speed
0.84 Mbps
0 Mbps 0.83 Mbps
Message 5 of 7
(451 Views)
Re: speed problem
13-05-2013 2:47 PM
Your speed profile is now matching your IP profile, give that another try.
Message 6 of 7
(451 Views)
Re: speed problem
13-05-2013 3:37 PM
Hi Chris, Yes that has sorted it.
Router Synching at 15.505, BT Profile 13.68, D/L speed 12.91.
Message 7 of 7
(451 Views)
