speed halved
- Re: speed halved
speed halved
12-10-2015 12:14 PM
Hello there
My speed has gone down to 6mbs from around 12. Could you kindly reset it please?
many thanks
many thanks
Message 1 of 9
(1,011 Views)
8 REPLIES 8
Re: speed halved
12-10-2015 2:46 PM
hello.........
anybody there
1 knock for yes 2 knocks for no.................
anybody there
Message 2 of 9
(691 Views)
Re: speed halved
12-10-2015 2:48 PM
now found something else..........no dial tone? tried another phone...same but internet working although slow as mentioned
Message 3 of 9
(691 Views)
Re: speed halved
12-10-2015 2:49 PM
in which case you need to report a phone fault as it sounds like one wire of the pair is broken
Message 4 of 9
(691 Views)
Re: speed halved
12-10-2015 3:01 PM
Hi fastconnection,
Thank you for bringing this to our attention. I have looked into this for you and can see there is a fault on you telephone line and I have raised this for you. You should receive a text message confirming the resolution time and no engineer is required to visit you. Please refer to ticket ref 112439470 in your online account.
Message 5 of 9
(691 Views)
Re: speed halved
12-10-2015 3:26 PM
Thanks Ben
Much appreciated
Much appreciated
Message 6 of 9
(691 Views)
Re: speed halved
15-10-2015 12:39 PM
phone fixed many thanks but speed id down to 5 - 6 from 10-11 .tried reset the router but just the same. could this be reset please?
thankyou
thankyou
Message 7 of 9
(691 Views)
Re: speed halved
15-10-2015 12:55 PM
Can you try a single disconnect/reconnect now?
Message 8 of 9
(691 Views)
Re: speed halved
15-10-2015 4:37 PM
That great alls well now. You guys are great. I have only had a few problems over the years but each time they have been fixed and you have kept in touch. Many thanks!
Message 9 of 9
(691 Views)
