so how can you see 'sync speeds' on fibre
- Re: so how can you see 'sync speeds' on fibre
05-10-2012 6:01 PM
DSL---> BT Modem --> CAT6-> Techicolor 582
The Techicolor has a web interface (and a telnet interface) that would normally tell me lots of good things about the DSL ... but of course it can't
because the line does not even get to the box.
The only place which would know the DSL characteristics would be the BT modem ... can I get stats off this somehow?
05-10-2012 6:07 PM
The only way is indirectly via the BT speedtest where the IP profile is about 96.7% of the sync speed
05-10-2012 6:28 PM
05-10-2012 6:38 PM
05-10-2012 6:45 PM
05-10-2012 7:21 PM
Quote from: dvorak Which of course would no doubt void any warranty and probably against the T's & C's
Of course it's not allowed, just technically 'do-able'
05-10-2012 9:23 PM
05-10-2012 10:06 PM
Quote from: Gigabit I stil do not understand why BT lock these modems down!
Maybe so that we can't mess with them & blame BT when our messing ruins our connections.
Or..........
[cynic]
So that we can't see exactly how bad our connections really are & to stop us having the proof with which to complain?
[/cynic]
05-10-2012 11:09 PM
Edit: Also where does http://192.168.1.78/html/content.asp ; fit in with all this?
06-10-2012 7:12 AM
Quote from: Anotherone Have I understood this right - Telnet into the Modem, type sh and at the # prompt then enter xdslcmd info --pbParams
Also where does http://192.168.1.78/html/content.asp fit in with all this?
Telnet Login is admin
password is admin
sh starts Busybox
Welcome Visiting Huawei Home Gateway
Copyright by Huawei Technologies Co., Ltd.
Login:admin
Password:
ATP>sh
BusyBox v1.9.1 (2010-10-15 17:59:06 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
# xdslcmd info --pbParams
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 4829 Kbps, Downstream rate = 32264 Kbps
Path: 0, Upstream rate = 4815 Kbps, Downstream rate = 26981 Kbps
Discovery Phase (Initial) Band Plan
US: (0,95) (868,1207) (1972,2783)
DS: (32,859) (1216,1963) (2792,3959)
Medley Phase (Final) Band Plan
VDSL Port Details Upstream Downstream
Attainable Net Data Rate: 4829 kbps 32264 kbps
Actual Aggregate Tx Power: 6.3 dBm 12.8 dBm
VDSL Band Status U0 U1 U2 U3 D1 D2 D3
Line Attenuation(dB): 8.3 54.3 N/A N/A 21.8 64.2 0.1
Signal Attenuation(dB): 9.3 53.7 N/A N/A 21.8 64.2 N/A
SNR Margin(dB): 6.0 6.1 N/A N/A 6.5 6.6 N/A
TX Power(dBm): -4.2 5.8 N/A N/A 11.4 5.8 N/A
http://192.168.1.78/html/content.asp is the modem's GUI
(actually the default 192.168.1.1 for my connection)
Another useful command is xdslcmd info --stats
That provides the usual connection stats including error counts etc.
Windows users can also fully graph their connection. See the link in the first post here:-
http://forum.kitz.co.uk/index.php/topic,10552.0.html
06-10-2012 3:39 PM
As well as loading new firmware, you need to also connect the 2nd LAN interface to your internal network.
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
