snr reset
- Re: snr reset
snr reset
31-03-2013 1:01 PM
Please could you reset my snr?
Thank you
Thank you
Message 1 of 9
(1,741 Views)
8 REPLIES 8
Re: snr reset
01-04-2013 10:00 AM
I can complete an SNR Reset for you but before I do, can I ask why you would like it resetting?
Message 2 of 9
(907 Views)
Re: snr reset
01-04-2013 5:45 PM
Because my speed is suffering given the current margin
Message 3 of 9
(907 Views)
Re: snr reset
02-04-2013 12:54 PM
Sorry, we don't perform SNR resets on request I'm afraid as we need to get to the bottom of what's caused the SNR to drop/rise so I'm going to advise raising a fault instead at this stage: http://faults.plus.net
Adam
Adam
Message 4 of 9
(907 Views)
Re: snr reset
03-04-2013 4:48 PM
I have contacted you privately, but have not received a reply.
Message 5 of 9
(907 Views)
Re: snr reset
03-04-2013 4:53 PM
Sorry will2012 A busy day in the forums means I've not been able to look at them until now.
Please don't think we're singling you out for any reason. All to often we're seeing requests for SNR resets where they're not needed, in some cases this can even cause further issues rather than be helpful.
As mentioned we'd rather get to the bottom of why the SNR might be low (i.e there may well be, as there is in many cases an underlying fault) before we'd like to consider performing one.
Adam.
Adam.
Message 6 of 9
(907 Views)
Re: snr reset
03-04-2013 5:57 PM
Thank you for your reply.
There is no fault on the line. I caused the issue doing exactly the same as someone else on here was doing recently,as I mentioned in my pm, and for them their requested snr reset was easy enough. I am not exactly sure which other conclusion you wish me to draw.
Message 7 of 9
(907 Views)
Re: snr reset
04-04-2013 9:46 AM
OK, I'll submit an SNR reset for you. We have to be careful with submitting these. Not that I'm accusing you of this but I'm aware that it's easy to misunderstand why and when an SNR reset is appropriate.
Adam
Adam
Message 8 of 9
(907 Views)
Re: snr reset
04-04-2013 4:43 PM
Thanks very much for your help
Message 9 of 9
(907 Views)
