snr reset?
- Re: snr reset?
snr reset?
06-02-2010 3:56 PM
how do i get my snr target reset to 6,it's been high since a fault a year ago and has never gone down again but the line is ok now
here are my router stats
ADSL Line State: Showtime
Mode: ADSL2PlusAuto
Transmit Power: 12.4 dB
Downstream Upstream
Bit Rate 2440 Kbps 843 Kbps
Cell Rate 5754 1989
SNR Margin 15.70 dB 6.0 dB
Line Attenuation 57.5 dB 33.5 dB
Fast Interleaved Fast Interleaved
CRC Errors 0 0 0 0
FEC Errors 0 0 0 0
HEC Errors 0 0 0 0
NCD Errors 0 0 0 0
OCD Errors 0 0 0 0
Mode: ADSL2PlusAuto
Downstream Upstream
Cell Rate 5754 1989
CRC Errors 0 0 0 0
FEC Errors 0 0 0 0
HEC Errors 0 0 0 0
NCD Errors 0 0 0 0
OCD Errors 0 0 0 0
Message 1 of 9
(1,798 Views)
8 REPLIES 8
Re: snr reset?
07-02-2010 1:51 PM
anyone ?
Message 2 of 9
(598 Views)
Re: snr reset?
07-02-2010 2:54 PM
Hi johnjarram
Just tested the line and I've noticed that you have a few Error seconds and HEC Erros on the upstream. I'm wonder why your router is not reporting any of these? Can you try an alternative router at the test socket please? Your router doesn't seem to be reporting everything precisely. Resetting the SNR will only put the line to the training period again which will conceal the problem or mask it for few days before it reappears.
Message 3 of 9
(598 Views)
Re: snr reset?
09-02-2010 12:51 PM
here are the stats from my thomson 585 v7 router
DSL Connection
Link Information
Uptime: 0 days, 0:06:54
DSL Type: G.992.3 annex A
Bandwidth (Up/Down) [kbps/kbps]: 787 / 1,891
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 33.5 / 54.0
SN Margin (Up/Down) [dB]: 6.0 / 15.0
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 82
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
DSL Connection
Link Information
Message 4 of 9
(598 Views)
Re: snr reset?
09-02-2010 9:49 PM
Hey johnjarram
Looking at the router stats, it is sync with ADSL2 modulation (G.992.3 annex A) :S not ADSL2+ (G.992.5 annex A). Does resetting the router and reconfiguring it makes any difference?
Message 5 of 9
(598 Views)
Re: snr reset?
10-02-2010 3:42 PM
no,i restored back to factory settings and it still is the same ,with the barely configurable firmware it doesn't have any option to change the adsl mode don't know if it can be done at your end of things
cheers john
cheers john
Message 6 of 9
(598 Views)
Re: snr reset?
10-02-2010 4:25 PM
During sync the Thomson 585v7 router will have determined that frequencies above 1.1kHz (used with ADSL2+ modulation) are too noisy to carry data so it has connected with the modulation that ignores the higher frequencies - ADSL2 (without the +) shown as G.992.3 annex A in the router interface. This is quite normal behaviour in that situation.
As you mentioned originally the target noise margin seems to be 15dB. Given a chance the 21CN DLM seems happier than the 20CN one to reduce the target noise margin if it judges that to be practical. Staying connected for a long time (perhaps 28 days) seems to figure in that logic. How often do you restart your router?
David
Message 7 of 9
(598 Views)
Re: snr reset?
10-02-2010 6:24 PM
usually everyday or 2 someone unplugs the router to use the plug socket,so i've put a multi plug on now and said i will glue the plug into the socket if it happens again
Message 8 of 9
(598 Views)
Re: snr reset?
10-02-2010 8:03 PM
That could be a good move.
The first hurdle seems to be 3 days of stability, but bearing in mind the line's history (as viewed by the DLM) it could take rather longer for things to happen. Hope it's sooner rather than later for you.
David
Message 9 of 9
(598 Views)
