slower speeds and higher pings "RESOLVED"
- Re: slower speeds and higher pings
21-10-2012 2:16 PM
Ive just ran a speedtest and it shows me with a high ping.
Normally my connection is speed is just under 8 meg and ping is 30.
So as you can see my speed is dropping and my ping is increasing ;(
Ill monitor this over the next few days and see how it goes.
21-10-2012 3:17 PM
21-10-2012 7:57 PM
Traffic Type: ATM
Status: Up
Link Power State: L0
Downstream Upstream
Line Coding(Trellis): On On
SNR Margin (0.1 dB): 54 301
Attenuation (0.1 dB): 320 138
Output Power (0.1 dBm): 0 123
Attainable Rate (Kbps): 9984 1052
Path 0 Path 1
Downstream Upstream Downstream Upstream
Rate (Kbps): 9814 444 0 0
MSGc (# of bytes in overhead channel message): 59 10 0 0
B (# of bytes in Mux Data Frame): 151 63 0 0
M (# of Mux Data Frames in FEC Data Frame): 1 1 0 0
T (Mux Data Frames over sync bytes): 2 1 0 0
R (# of check bytes in FEC Data Frame): 12 0 0 0
S (ratio of FEC over PMD Data Frame length): 0.4939 4.5309 0.0 0.0
L (# of bits in PMD Data Frame): 2656 113 0 0
D (interleaver depth): 64 1 0 0
Delay (msec): 7.90 1.13 0.0 0.0
INP (DMT symbol): 1.15 0.0 0.0 0.0
Super Frames: 6041658 723102 0 0
Super Frame Errors: 0 0 0 0
RS Words: 785415670 0 0 0
RS Correctable Errors: 47136502 0 0 0
RS Uncorrectable Errors: 315857 0 0 0
HEC Errors: 4294967044 54124 0 0
OCD Errors: 36 0 0 0
LCD Errors: 0 0 0 0
Total Cells: 2244838824 296260 0 0
Data Cells: 274766430 12628 0 0
Bit Errors: 0 0 0 0
Total ES: 12100 4294967289
Total SES: 1580 0
Total UAS: 64 4294967244
Firmware Version: 1.4.0 Build 110921 Rel.17774n
Hardware Version: TD-W8960N v3 0x00000002
This information reflects the current status of your DSL connection.
Line Rate - Upstream (Kbps): 444
Line Rate - Downstream (Kbps): 9814
LAN IP Address: 192.168.1.1
Default Gateway: 195.166.128.192(pppoa0)
Primary DNS Server: 212.159.6.10
Secondary DNS Server: 212.159.6.9
System Running time: 4 day(s) 23:57:58
C:\Users\>ping bbc.co.uk
Pinging bbc.co.uk [212.58.241.131] with 32 bytes of data:
Reply from 212.58.241.131: bytes=32 time=40ms TTL=246
Reply from 212.58.241.131: bytes=32 time=33ms TTL=246
Ping statistics for 212.58.241.131:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 33ms, Maximum = 40ms, Average = 34ms
21-10-2012 8:14 PM
Quote D (interleaver depth): 64 1 0 0
http://www.kitz.co.uk/adsl/interleaving.htm explains an interleave depth (especially a gigantic 64) better than I could.
BTW I don't know why you have two paths...
21-10-2012 8:18 PM
21-10-2012 8:29 PM
Ive just ran a speedtest and it got stuck at that my connection right now seams very sluggish and some webpages dont load correctly. Something is not right but i dont know if its my router or if its my line/connection.
Would be great if someone from plusnet could check this out for me, maybe i should drop a suport ticket in ?
21-10-2012 8:41 PM
21-10-2012 8:51 PM
This is a good thing.
But this increases your latency.
This is a bad thing.
This is due to some interference on your line (somewhere)
You need to raise a ticket with Plusnet - who will start by suggesting a few causes.
They will also want you to use the BT speedtester.
BTW When you do your speedtests, always try them against the same high capacity destination.
I tried pinging your ip address (displayed) but you weren't there any more.
Don't switch off your router (ever) in normal use and certainly not more than once an hour.
BT think you got a brief line error.
21-10-2012 8:56 PM
shows me have 1 meg speed it seams to be getting slower by the hour
Theres deffo some kind of problem
Re: slower speeds and higher pings "help needed"
21-10-2012 9:00 PM
21-10-2012 9:00 PM
21-10-2012 9:06 PM
Definitely not a reboot!
21-10-2012 9:15 PM
21-10-2012 9:32 PM
Login as you do for stats - and look for what RPM has said. I'll post more in a moment.
21-10-2012 9:37 PM
