slow speed just changed from sky
PhilB1
hi i have just changed from sky broadband to plusnet and my speed is a little slower. on sky my router used to connect at around 10mbps and the download speed was around 9mps but now on plusnet it connects at 7 and downloads at about 6mbps. could someone take a look for me please.
3 REPLIES 3
Gel
Aspiring Champion
Fixes: 29
Re: slow speed just changed from sky
You'll now be connecting via the BT Openreach network, which is possibly why.
PN should have given you a speed estimate at time of joining; saying that, you
should give connection a few days for the network to determine your maximum/ sustainable speed.
Check your line's potential at:
http://speedtest.btwholesale.com/
Chris
Legend
Fixes: 169
Your line seems to be disconnecting quite a lot:
Can you confirm you're plugged in to the master socket and if there is any noise on the phone line when you dial 17070, running the quiet line test?
PhilB1
Hi it is plugged directly into the master socket, it is a by mk3 prefiltered socket and has no phone extensions from the socket. Did the line noise test and there is no noise.
