slow.disconnect..slow.disconnect..engineer..slow disconnect. you get the pic.
- slow.disconnect..slow.disconnect..engineer..slow d...
- « Previous
- Next »
Re: slow.disconnect..slow.disconnect..engineer..slow disconnect. you get the pic.
25-11-2013 10:31 PM
Have raised PN fault ticket.
FYI routerstats Lite doesn't have the overlay option.
Things continue to get worse with loss of connection, graphs are show countless drops.
P
P
Message 31 of 35
(207 Views)
26-11-2013 9:20 AM
P,
These gaps are horrible! You seem quite confident with this monitoring technology. I suggest that you switch to the full RouterStats version and enable Telnet mode. This will also show tone and bit swap data.
Hopefully someone from DCT will pick this up soon and get an action plan in place for REIN investigation.
Just a passing thought - is your monitoring PC connect by wire or wifi to the router? If there is wifi interference (check with inSIDDer) then the monitoring PC cannot collect the stats during that interference resulting in a distorted view of the issue. I have also seen a flaky TG router not return stats due to being very busy managing FECs.
Cheers,
Kevin
Cheers,
Kevin
Message 32 of 35
(207 Views)
26-11-2013 10:13 AM
Hi help,
I've just had a look over your Fault ticket and can see that you've mentioned about having noise on your line - is this constant noise or does this just happen from time to time?
Message 33 of 35
(207 Views)
26-11-2013 6:46 PM
Hi Chris,
The phone isn't usually plugged in, I use the line solely for broadband. When I plugged the phone in to check when going through the fault steps to raise the ticket, there was a lot of static. I have left the phone in and have been checking from time to time. It doesn't seem to be constant. However I wanted to answer the question as best as poss when raising the ticket. Have now been sent email requesting another engineer visit. It also says in the email that testing on the line hasn't revealed any problem. Advice?
P
P
Message 34 of 35
(207 Views)
27-11-2013 11:03 AM
As you've done all the checks to prove it is a fault on the line and not with any equipment or wiring at your premises, booking the engineer visit will be the best way to progress the fault for sure - if you let us know when you're available (weekdays either in the mornings between 8am and 1pm or afternoons between 1pm and 6pm) we'll get it arranged for you.
Message 35 of 35
(207 Views)
- « Previous
- Next »
