slow broadband
andrewkerrj
slow broadband
My broadband speed has got really slow in the last couple of days. Usually my download speed is around 7Mbps but is currently less than 2Mbps.
Also, I sometimes lose the Internet connection on my router, which is bad when I'm in the middle of a Zoom call, for instance.
A massive wait if I call 0800 432 0200.
Can anyone help, please? Thanks.
3 REPLIES 3
Legend
Fixes: 255
Re: slow broadband
@andrewkerrj  Welcome to the forums. Plusnet staff support, like the phone service, is still severely restricted. If you would like help from the community, a good starting point is to have a look at This post and supply as much detail from it as possible.
It would also be a good idea to carry out a 'Quiet Line Test' - dial 17070 from a (preferably corded) phone and select option 2 - there should be no discernable noise. If there is, report a phone fault first, as without a clear phone connection, your broadband will not perform correctly.
If you reply to this topic with as much detail as possible, there are plenty of experienced members who can advise on possible remedies.
If you decide to also post on the Twitter/Facebook accounts and get a response from there, please come back here and say so.
andrewkerrj
Re: slow broadband
Thanks, John. Yes, the line is noisy - lots of crackling. So, I'd better report a line fault, then? Thanks.
Legend
Fixes: 255
Re: slow broadband
@andrewkerrj Correct - report a phone fault first, it may well rectify your broadband problem.
