slow broadband with plus net
Chris
Legend
Fixes: 169
Re: slow broadband with plus net
If you're still having connection I'd strongly suggest going through the steps at https://faults.plus.net as this will go through some troubleshooting, run an automated line test and then pass the ticket into our faults team for investigation.
zulfi5
slow speed
hi, can plusnet fault team look at my conaction and uncap the download speed it stock at 4mb and it was full before  pls.?
thanks
Oldjim
Resting Legend
Fixes: 63
New topic merged into existing thread
Have you gone through the faults process as suggested and, id so, what was the result
zulfi5
i have  gone through the faults process as suggested and it said my interner,wireing fault but every things work fine just the slow broadbandi thinks my download speed has caped .?
Oldjim
Resting Legend
Fixes: 63
If it is your internal wiring as they suggest then connecting to the test socket - not the master socket - should sort it
Can you connect to the test socket and advise the full stats
zulfi5
The test socket and  full
Line state: Connected
Connection time: 0 days, 00:01:54
Downstream: 4.211 Mbps
Upstream: 888.9 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.3 Annex A
Latency type: Interleaved
Noise margin (Down/Up): 12.1 dB / 10.8 dB
Line attenuation (Down/Up): 43.7 dB / 25.8 dB
Output power (Down/Up): 18.6 dBm / 12.7 dBm
FEC Events (Down/Up): 13 / 0
CRC Events (Down/Up): 0 / 22
HEC Events (Down/Up): 0 / 9
Error Seconds (Local/Remote): 129 / 34
zulfi5
hi,
can plusnet fult look at my conaction, pls my broadband speed slow again>?
chrispurvey
Hi zulfi5,
I checked over your line and can't see any obvious cause for your slower speeds. I can see that you opened a fault ticket but closed it before all of the initial checks were completed.
Would you be able to open another fault ticket so we can investigate this further?
bobpullen
Fixes: 316
Further to what Chris has said, your BT line profile is set to 4453kbps. Your downstream SNR is a tad high which results in a lower connection speed but that's probably something to do with the frequency at which your connection is dropping out:
Session Started	Session Ended	Session Duration
14:41 08/May/2013 N/A   0:28:28 (on going)
14:25 08/May/2013 14:41 08/May/2013   0:16:1
14:22 08/May/2013 14:24 08/May/2013   0:2:20
14:58 07/May/2013 14:21 08/May/2013   23:23:10
00:44 07/May/2013 14:55 07/May/2013   14:10:43
13:07 06/May/2013 00:42 07/May/2013   11:35:30
12:45 06/May/2013 12:52 06/May/2013   0:7:46
12:38 06/May/2013 12:41 06/May/2013   0:2:46
17:59 05/May/2013 12:37 06/May/2013   18:37:32
17:56 05/May/2013 17:57 05/May/2013   0:1:9
17:44 05/May/2013 17:54 05/May/2013   0:9:37
17:41 05/May/2013 17:42 05/May/2013   0:0:49
15:03 05/May/2013 17:41 05/May/2013   2:38:7
14:36 05/May/2013 15:03 05/May/2013   0:26:34
14:25 05/May/2013 14:36 05/May/2013   0:11:33
14:09 05/May/2013 14:24 05/May/2013   0:15:51
You've done the right thing by opening a fault report. Just a case of waiting patiently for our Faults Team to run some tests etc.
