slow broadband with plus net
zulfi5
i have half of my speed with plusnet before o2 and sky i have sable speed 6 mb but know i have 2.7 download speed can plus net fualt teame cheack my line pls. my modem conact to master soucket and i have bt face plate .?
23 REPLIES 23
adamwalker
Fixes: 221
Re: slow broadband with plus net
It looks like the line is banded between 1 and 3mb. We can hopefully have that sorted by close of play on Monday for you.
Adam
 Adam Walker
Pettitto
Fixes: 5
I've just noticed that your line is banded.
I'm going to remove the banding to see how your line performs. Could you let me know if you start seeing any disconnections at all?
zulfi5
hi,
thanks for speedy reply  my broadband speed now increase to 4.2 but my modem can`t contact to adsl2+ it only conact,to adsl2 my exchange has adsl2+ 21cn wsb.can plus net fult team check, it pls.?
Oldjim
Resting Legend
Fixes: 63
That is the automatic system at the exchange - with the speed you are seeing ADSL2+ would have no effect
Please post the full stats from the router as it is likely that the default noise margin is 15dB
zulfi5
thanks for reply
ADSL Line Status
Connection Information
Line state: Connected
Connection time: 0 days, 02:50:48
Downstream: 5.181 Mbps
Upstream: 440 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.3 Annex A
Latency type: Interleaved
Noise margin (Down/Up): 11.0 dB / 25.4 dB
Line attenuation (Down/Up): 43.6 dB / 25.7 dB
Output power (Down/Up): 18.7 dBm / 12.4 dBm
FEC Events (Down/Up): 2068095 / 0
CRC Events (Down/Up): 106 / 0
HEC Events (Down/Up): 41 / 0
Error Seconds (Local/Remote): 520 / 0
Oldjim
Resting Legend
Fixes: 63
OK not 15dB but probably 12dB
You can't do anything about that until the 10 day training period is over.
If it hasn't changed and the line has been stable Plusnet may be willing to initiate SNR reset which will get you back to 6dB
Do you want the upstream uncapping - if so either raise a ticket or wait for it to be picked up here
zulfi5
Plus net fault team can I have upstream uncap SNR rest pls?.
chrispurvey
I've placed a SNR reset on your line that will take affect in the next 4 hours, I've also placed an order to uncap your upload which will complete tomorrow.
Innovations
Chris!
Are you there?Huh
You seem like a decent chap -can you take my 0.25Mb throttle off?
adamwalker
Fixes: 221
@Innovations
I've just sorted that for you.
 Adam Walker
zulfi5
Still slow broadband speed
Pettitto
Fixes: 5
Hi zulfi5,
I'm really sorry to hear you're still suffering with poor speeds. What sort of speeds are you getting at the moment?
Can you please complete the BT Speedtester at http://speedtest.btwholesale.com so we can take a look please?
zulfi5
bt test
1Download speedachieved during the test was - 3.82 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
IP Profile for your line is - 3.92 Mbps
Upload speed achieved during the test was - 0.69Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
zulfi5
can some bady plusnet fult team  look at my conaction detail pls.
thanks
