slow broadband and ping
- Re: slow broadband and ping
22-01-2013 9:46 PM
Having problems with broadband being slow and erratic pings, things seem to have been downhill gradually since changing over to unlimited and removing pro add on so dont know if its just a coincidence to coincide with the bad weather or something else causing the issue, any way a staff member can check to see if everything is ok on your end
Message 1 of 8
(2,327 Views)
7 REPLIES 7
22-01-2013 9:49 PM
There's a few similar threads over the last week or so, we've got a piece of unhappy network kit that we're fixing. For now you can log in to the router, press disconnect and then connect.
When you're back online check here: usertools.plus.net/@gateway and if the result doesn't start with PCL then you should be ok.
Message 2 of 8
(767 Views)
22-01-2013 10:04 PM
I'm having issues tonight also chris, apparently I'm on gateway pcl-ag06, is this a problem?
Message 3 of 8
(767 Views)
22-01-2013 10:09 PM
I was connected to pcl then I disconnected and reconnected and now it starts with ptn, is that good?
Message 4 of 8
(767 Views)
22-01-2013 10:25 PM
pcl-ag06 is affected. ptn-* should be fine.
Kelly Dorset
Ex-Broadband Service Manager
Message 5 of 8
(767 Views)
22-01-2013 10:27 PM
Ah right ok, on my router I don't have a disconnect option only a reboot option, is that ok to do?
Message 6 of 8
(768 Views)
22-01-2013 10:28 PM
Yeah, just don't do it too often.
Kelly Dorset
Message 7 of 8
(768 Views)
22-01-2013 10:35 PM
Success! Thanks guys
Message 8 of 8
(768 Views)
