skype and msn messenger voice messaging connection stuttering
- skype and msn messenger voice messaging connection...
08-11-2007 6:33 PM
Do Plusnet actively block these types of connections?
Is it due to my region and the exchange here? (Chesham, Buckinghamshire)
My modem reports:
DownStream Connection Speed 8096 kbps
UpStream Connection Speed 448 kbps
I'd really like to get this working.
Thanks!
Re: skype and msn messenger voice messaging connection stuttering
08-11-2007 6:42 PM
Web-based speed tests are varied but coming in quite a lot lower than my modem/router reports:
download: 2500 - 6500
upload 350 - 450
08-11-2007 6:43 PM
Do you notice any issues when trying to view web pages at all?
I'm just wondering if your connection itself is actually dropping, thus causing the problems you speak of.
It could also be possible that your problem is down to MTU/rWin values. We've got a handy video showing you how to set these up here:
http://www.plus.net/support/broadband/troubleshooting/rwin_video.shtml
This may also help to ensure that you're getting optimal throughput speeds.
08-11-2007 7:01 PM
I cannot get the tweak tester to work unfortunately. It just says "* Downloading file of size 1024000: " and hangs. I have followed the instructions and edited my Windows firewall (XP) by going to Advanced tab, selecting "1394 Connection" clicking "settings..." and added services on my local IP 192.168.0.2 External port 8086, internal port 8086 and same again for port 8085 (should these be both internal and external port numbers?)
I have a Netgear DG834PN router/modem running on IP 192.168.0.1 but cannot see any port settings in there
08-11-2007 7:08 PM
Try downloading DR.TCP as per the video tutorial and then enter these settings:
MTU: 1430
Receive Window: 111200
Make sure that you also set the MTU as 1430 on your router and then reboot both your router and computer and see how you get on.
08-11-2007 7:11 PM
08-11-2007 7:15 PM
Quote from: Jameseh MTU: 1430
Can I ask why 1430 is suggested as it seems rather low.
My Netgear Router (DG834GT) has always had it's MTU set to 1500.
PC MTU should be the same size.
08-11-2007 7:17 PM
I personally saw an increase in throughput of roughly 3.5Mbps when I changed my MTU to 1430.
Why did I select this amount? Dave told me to
08-11-2007 7:28 PM
08-11-2007 11:11 PM
It can happen if you have a large contact list or if windows update is running but there is no fix for the problem at the moment.
As the cpu goes to 100% everything stops
12-11-2007 2:21 PM
