significant drop in download speed, upload unchanged
- significant drop in download speed, upload unchang...
11-03-2010 12:34 AM
Upgraded to plusnet pro in december, since when I've had ~4.5Mb down consistently, 443kb up. End of last week download speeds fell to < 100kb down. Here is current router stats -- which changed slightly for the better yesterday, but not by much.
ADSL Link Downstream Upstream
Connection Speed 574 kbps 443 kbps
Line Attenuation 36.0 db 20.2 db
Noise Margin 31.0 db 28.1 db
and speed test results.
I have router connected to master socket with filter and 1 other phone in separate extension also with a filter.
Any thoughts?
Thanks....
Re: significant drop in download speed, upload unchanged
11-03-2010 7:32 AM
11-03-2010 9:48 AM
I suspect you had a massive burst of noise on the line causing a very low resync. The noise has gone so the noise margin has leapt up
Are you sure you don't have 448kbps up
11-03-2010 9:50 AM
Quote Connection Speed 574 kbps 443 kbps
That's why your results on a speedtest are so low, that figure is the speed your router is syncing at with the exchange.
The noise margin is incredibly high on your line, have you made any changes to the electrical wiring or added new appliances in your premises?
Your connection looks extremely intermittent and appears to be dropping out quite frequently, this will be the cause of the low speeds you're seeing. Can you try swapping the filters over and seeing if the line remains stable, it would be worth temporarily removing whatever is plugged into the other extension while performing this test.
11-03-2010 10:04 AM
11-03-2010 2:00 PM
Chris -- aware it's the connection speed that's the problem. Previously router was syncing at much higher rates -- 7000+ downstream. Have not made any electrical changes. Will try 1) removing the other phone and resyncing, and 2) with phone removed swapping filters. Is the 31.0 db 28.1 db down/up noise margin considered very high? What should I be expecting.
will post update tonight.
Thanks.
11-03-2010 3:25 PM
11-03-2010 7:56 PM
Swapped this filter with the one from the router. Reconnected to the master socket and resync'd.
Results are much the same:
Noise Margin 30.2 db 27.7 db
any thoughts on next steps? many thanks.
11-03-2010 8:02 PM
Hopefully a rep will pick this up as something is completely wrong.
If you were on 21CN I'd say it was a banded profile
11-03-2010 8:25 PM
11-03-2010 8:30 PM
A downstream sync speed of 574kbps is just inside the upper limit of the 288-576kbps band, and an upstream sync of 443kbps, just under the normal 448kbps fits often seen 21CN behaviour.
11-03-2010 8:48 PM
11-03-2010 9:07 PM
12-03-2010 12:08 AM
Hopefully the faults team will be able to help resolve the problem in response to your fault ticket.
12-03-2010 2:21 PM
This is spot on, checking for a banded profile gives the following: WBC 288K - 576K Medium delay
Looking at the recent connection logs, you've had a large number of disconnections recently, have you been rebooting the router alot (and I mean 58 times in the last week)?
If not then it would mean something is causing this intermittent connection and your speed isn't going to improve until the intermittent connection is fixed. I'll update your ticket (sorry it's a standard response with some questions to make sure we get the answers needed).
If you can let me know when the questions have been replied to we'll get the fault tested again and raised straight away.
