should i of gone to specsavers (banding removed after months)
- should i of gone to specsavers (banding removed af...
26-09-2009 2:06 PM
should i of gone to specsavers or does that sync now not read 3074
Place your bets as to how many days it takes for the DLM to have me back on a fixed sync rate again
Couldnt resist using roterstats to tweak (kick the DLM between the legs) and try a 20% drop in noise margin after its been in control for so many months
so its removed the fixed sync control but still left me on a 15db noise margin as it was on a fixed sync rate. i would like to think if the DLM plays ball it might try 12db soon and stay there but from past exprince of watchin what the 21cn DLM does with my line it will skip 12db and jump straight to 9db at a massive 4554 sync an kill its self and chuck me back on 15db fixed sync again.
i do belive my DLM cant do maths and dosent know what the number 12 is
Quote Noise Margin: 14.1 dB
Connection Rate: 3299 Kbps
Line Attenuation: 50.0 dB
Power: 0.0 dBm
Max Rate: 4368 Kbps
SF: 9269
SF Errors: 1
Reed Solomon: 0
RS Corrected: 0
RS Un-Corrected: 0
HEC: 1
Errored Seconds: 1
Severe ES: 0
Interleave Depth: 1
Message 1 of 2
(910 Views)
1 REPLY 1
Re: should i of gone to specsavers (banding removed after months)
26-09-2009 6:02 PM
In base 13, 12dB = 15dB (decimal arithmetic)
Message 2 of 2
(299 Views)
