should I jump to your way pro
amcclean
When the new packages came out I moved to your way option 2 and was frustrated by the speed restrictions on some file usage. I decided to live with it as moving to a higher package was too expensive. Now I have my net paid for and am considering moving to your way pro.
If I move to your way pro i trust reading from the help pages and pn tables re restrictions that I'll no longer have restrictions placed on my download speeds. ie speeds wont be held to a max of 70Kbps.
I don't use 1/2 the 8gb allowance so will be using a smaller % of the new allowance. The is a doubling of the phone allowance to 240 mins.
Has anyone regretted moving to pro your way?
also would I have to start a new 12 month contract I don't need router or the games voucher.
A
2 REPLIES 2
James
Re: should I jump to your way pro
Hi Podman,
Whilst I appreciate that you're after some advice from some fellow customers, I'd just like to let you know that "Pro" comes on a monthly contract and all traffic will be prioritised as Gold & Titanium with no rate limits in place.
amcclean
cheers I decided to make the move. back to nice quick speeds 🙂
R
