router turn off overnight or not
- Re: router turn off overnight or not
- « Previous
- 1
- 2
- Next »
27-10-2011 9:10 AM
As I recall when you first join an ISP....
You line is subject to a 10 day training period. Part of this is to establish the LOWEST sync that the line would normally connect at during the period.
Your fault level is then set at a certain percentage below this lowest sync level.
Any sync subsequently obtained down to this preset fault level would not normally be considered as a "fault".
Message 16 of 17
(173 Views)
27-10-2011 11:33 PM
Quote from: x47c Your fault level is then set at a certain percentage below this lowest sync level.
Right Thanks
Think i will carry on as i have been for the time being, if i leave the router on, and let it and bRAS do its thing im likely to end up with a connection much slower then i have now, but still just within the “acceptable?” speed for my line.
Mike
Message 17 of 17
(173 Views)
- « Previous
- 1
- 2
- Next »
