router drop out
- router drop out
Re: router drop out
22-04-2012 6:51 PM
Re: router drop out
22-04-2012 10:45 PM
orange with small white..... 3
white with small blue..... 5
Re: router drop out
23-04-2012 1:12 AM
Have a look at the Kitz site for an explanation and illustrations.
Re: router drop out
23-04-2012 7:57 AM
but i will remove when i get home to see if that makes any difference
what about them iplate things would that help
Re: router drop out
23-04-2012 8:15 AM
as Jaggies has mentioned, remove the orange wire from terminal 3 on the front plate, there's nothing at the back of the test socket except the feed from the exchange (usually) apart from which you shouldn't touch that, that bit is OpenReach's responsibility.
If there were a white/orange wire on terminal 4, that can be removed as well. Do this at the back of the extension socket(s) as well.
As you have broadband, those wires are not needed at all, even for older phones. The filter creates its own local ring (bell) wire.
Having disconnected the ring wire, an iplate would unlikely make any difference. apart from which if your front plate has the OpenReach logo on it, it won't fit. It only fits to the previous version of the master socket front plate with the BT logo. The latest OpenReach socket has a bell wire filter in it, but it is still better to remove the orange wires.
Re: router drop out
23-04-2012 5:31 PM
so the orange wire wont make alot of difference
Re: router drop out
23-04-2012 6:04 PM
Can you post the latest ADSL line stats from your modem/router.
Re: router drop out
23-04-2012 6:17 PM
How can this modem be syncing at 4864 with an attenuation of 48dB and a SNR of 15.5dB? Correct for 6dB - but 15.5dB? Sounds all wrong to me!
Could this be the reason for all the disconnects? Too high a sync for the line capability?
Probably all wrong, just thought I'd ask.
Downstream Upstream
SNR Margin : 15.5 19.0 db
Line Attenuation : 48.0 24.5 db
Data Rate : 4864 448 kbps
Max Rate : 5184 984 kbps
CRC : 41 0
Re: router drop out
23-04-2012 6:21 PM
SNR Margin : 17.5 19.0 db
Data Rate : 4832 448 kbps
Max Rate : 5056 956 kbps
CRC : 4 0
Re: router drop out
23-04-2012 6:56 PM
SNR Margin : 17.0 19.0 db
CRC : 4 0
Re: router drop out
23-04-2012 7:12 PM
No, no real problem with the stats, with a high quality line that can be achievable. What would you say to 7552kbps with 42 dB attenuation and a 7.1dB noise margin ?
Starkie1800, I assume that's the same modem/router as yesterday, don't want any changes at the moment whilst we consider the next move. Your noise margin has increased since that last resync which means either the noise is up and down like a yoyo, or something causing noise has gone away at the moment. Thanks for those last stats, was just going to ask for them! Another set about 8.pm if you can manage it. Also late tonight as late as you wish to manage.
Just want to try and clear up a couple of points, what was happening when it last dropped, were you there did you notice anything, have a chance to pick up the phone?
Going back to your original post, can you clarify in a bit more detail what you were doing at the time, you talked about your system log. Then in reply #2 you talked about clearing out the old log and resetting the router, was this when you were talking about the logs in the original post or later?
When you posted stats yesterday morning about 1000, was there anything electrical running then that isn't now that you know of?
Re: router drop out
23-04-2012 7:18 PM
4/23/2012 19:11:23> netMakeChannDial: err=-3000 rn_p=8062f4c0
4/23/2012 19:11:49> Last errorlog repeat 14 Times
4/23/2012 19:12:2> netMakeChannDial: err=-3000 rn_p=8062f4c0
4/23/2012 19:12:3> Last errorlog repeat 2 Times
4/23/2012 19:12:12> netMakeChannDial: err=-3000 rn_p=8062f4c0
4/23/2012 19:12:19> Last errorlog repeat 44 Times
sys log
catching phone when drops out maybe hard but will try and yes tp-link w8951nd
sometimes not online or using router as such just see the lights go out then 30-60 seconds it back up
Re: router drop out
23-04-2012 8:05 PM
CRC : 7 0
Re: router drop out
23-04-2012 8:18 PM
I don't know what to make if that sys log at the moment.
Edit: What version tp-link w8951nd is that you are using?
Re: router drop out
23-04-2012 9:14 PM
Downstream Upstream
SNR Margin : N/A N/A db
Line Attenuation : N/A N/A db
Data Rate : N/A N/A kbps
Max Rate : N/A N/A kbps
CRC : N/A N/A
4/23/2012 21:10:32> MPOA Link Down
4/23/2012 21:10:32> SNMP TRAP 2: link down
4/23/2012 21:10:32> netMakeChannDial: err=-3001 rn_p=8062f4c0
4/23/2012 21:10:42> Last errorlog repeat 10 Times
4/23/2012 21:10:47> netMakeChannDial: err=-3001 rn_p=8062f4c0
4/23/2012 21:10:48> netMakeChannDial: err=-3001 rn_p=8062f4c0
4/23/2012 21:10:49> Last errorlog repeat 2 Times
back on
Downstream Upstream
Data Rate : 4384 448 kbps
Max Rate : 4576 964 kbps
CRC : 0 0
