repeated dropout of internet connection in Compton
- Re: repeated dropout of internet connection in Com...
- « Previous
- 1
- 2
- Next »
Re: repeated dropout of internet connection in Compton
04-02-2016 1:01 PM
I'll have to see what BT say, if they try to shrug it off then I guess I'll have to tempt them with an offer to move to their broadband product otherwise I'll have no other possible solution.
Message 16 of 23
(669 Views)
04-02-2016 1:24 PM
You can also run a line test and report the fault through the BT website. If the line test shows a fault somewhere on the network before your property, I think it's quite easy to get it fixed.
Message 17 of 23
(669 Views)
04-02-2016 4:41 PM
Quote from: Chris Unfortunately any issues with the copper line would be down to the phone provider to resolve, we can only perform a basic test on that side of the circuit (which we did and showed a fault).
Unfortunately, Chris, this attitude is what is causing some customers problems. PlusNet say the problem is down to the phone provider and the phone provider say the problem is down to the Broadband supplier and the customer is left in the middle not knowing what to do. As far as I am concerned then if the customer is having problems with their Broadband and raise the issue with PN then it should be up to PN to raise the problem with the phone provider if necessary and chase/follow up the problem until it is resolved. This would have the added benefit of 2 knowledgeable parties being able to discuss the issue instead of the less knowledgeable customer. This is called customer service and increases customer satisfaction hence customer retention and hence long-term profits. The other method is called washing your hands of the problem and has the opposite effect.
Message 18 of 23
(669 Views)
04-02-2016 4:51 PM
I think BT would say if one of their customers had a phone fault, it should be reported to them by their customer.
Their customer can then authorise any action that needs to be taken.
Message 19 of 23
(670 Views)
04-02-2016 7:43 PM
I think that sounds like if I now have a problem that I'll end up paying BT to fix it. I didn't ask for this upgrade and I didn't cause the problem.
dick:quote
dick:quote
Message 20 of 23
(670 Views)
04-02-2016 9:01 PM
If you run the line test on the BT website, and it says the fault is likely to be at the exchange or somewhere on the network nowhere near your house, then if you continue and actually report the fault, then an engineer may get sent to wherever the fault is. If the engineer doesn't visit your home, it's unlikely they'll be able to blame it on your extension wiring or equipment, so it's unlikely you'll be charged.
Message 21 of 23
(670 Views)
13-02-2016 10:58 AM
You cant' really put the blame on PN for a phone line fault. If you don't rent pay your line rental to them, then it makes no sense for them to sort it out. Good advice is to always have the phone and the broadband of any flavour suplied by the same company and this has been the cases since ADSL came on stream a decade or more ago.
I'll leave it to you to decide which way to go, but switching to PN for phone is about £1 a month cheaper than BT .
Message 22 of 23
(670 Views)
19-02-2016 11:17 AM
Quote from: gpsmout You cant' really put the blame on PN for a phone line fault. .....switching to PN for phone is about £1 a month cheaper than BT .
But even then they can still blame BT if you have a problem, saying it's a wholesale supplier (ie BT Openreach) issue.
But the issue really is that the customer often doesn't know if it's a phone line fault or something else.
And lets remember you are paying PN for a service (Broadband), so it is up to them to deliver that service. Saying you can't blame PN is again washing hands of the problem. What if PlusNet doesn't pay their electric bill and all their servers go down...."Oh you can't blame PlusNet for the electrical supply!", so what are PlusNet actually being paid for then?
Message 23 of 23
(670 Views)
- « Previous
- 1
- 2
- Next »
