recording sync speed drops
- recording sync speed drops
20-03-2008 10:24 PM
Anyone know of programs that can monitor sync speeds and record any drops. I am using Netgear DG834G. I have a suspicion that there is an event that is causing a drop during the day or evening. Thanks. Peter
Message 1 of 9
(2,112 Views)
8 REPLIES 8
Re: recording sync speed drops
20-03-2008 10:35 PM
u can use this to monitor snr u can set it to monitor at defrent time intervals i use mine at 2 secs if i have bein getting problem speeds.
im not sure if it works with your netgear router but check the web site.
http://dmt.mhilfe.de/
Message 2 of 9
(673 Views)
20-03-2008 11:14 PM
That tool does not work with the Netgear.
To monitor your netgear you need to use Routerstats
Message 3 of 9
(673 Views)
Netgear Program
20-03-2008 11:20 PM
Message 4 of 9
(673 Views)
20-03-2008 11:28 PM
Sorry. See Netgear prog.
The reply did not get in the right "reply".
Message 5 of 9
(673 Views)
20-03-2008 11:50 PM
Quote from: Peter That tool does not work with the Netgear.
?? It works fine for me - DG834GT.
You need to get the right version for your router.................
Message 6 of 9
(673 Views)
21-03-2008 12:00 AM
That is a totally different router to the DG834G even though the name appears to be similar. It uses different hardware and chipset.
Message 7 of 9
(673 Views)
21-03-2008 9:09 AM
Ooops, I should learn to read more carefully!
Shame, DMT is really useful but doesn't work with the DG834G.
Message 8 of 9
(673 Views)
21-03-2008 4:02 PM
Thanks everyone. Got Routerstats up and running now. Happy Easter to all.
Peter
Peter
Message 9 of 9
(673 Views)
