recommendation please.
indybutts
Hi folks i have just purchased a netgear dg834gt wireless router,i would like to replace the wg111t  that comes with it for my laptop with an internal card.
Any recommendations gratefully accepted.
2 REPLIES 2
Denzil
Re: recommendation please.
You mean you want a PCMCIA wifi card instead of the WG111T USB thing? Any of them from a reputable brand should do the job.
There are loads on <a href="http://www.ebuyer.com/cat/Wireless/subcat/Adapters---PC-Cards"> Ebuyer</a> for example.
HPsauce
If you've got a DG834GT router I'd advise going for the corresponding 108mbps Netgear card.
I know you won't need the speed when connecting to t'internet but the better connection does improve throughput especially as you move into marginal signal territory.
