re bad connection
re bad connection
is it just me i keep getting cut of and my pc is not connecting to my router wirelessly it connects to all others any suggestions to what the problem can be i rang plus net who says my connection is fine
1 REPLY 1
Fixes: 62
Re: re bad connection
Can you clarify.
Is your router losing sync with the exchange or are you losing the wireless connection to the router.
If the latter can you describe your setup - router type, computer wireless type, distance from computer to router and through how many walls.
